Fuel Injectors?
Fuel Injectors?
I was trying to do some window shopping on google to find out what place might be the cheapest to get a full set of injectors from and saw this site:
http://www.fiveomotorsport.com/Injector_SetsNISSAN.asp
6/Set: $339.50
Plus $90 Refundable
Core Charge
Seams REALLY cheap; almost half of anyone else. My thoughts are that they are most definatly remanufactored, but hell if they work for another 150k miles, then awsome for that price. So any thoughts? Opinions?
6/Set: $339.50
Plus $90 Refundable
Core Charge
they're remanufactured, 3 year warranty though. http://cgi.ebay.com/ebaymotors/Nissa...ayphotohosting
you might want to check if it's a full warranty though. from how it reads it seems like maybe if the coils go, you won't be covered.
Ok, I will repeat what I said in another thread.
I have spoken to multiple rebuilders that are reputable and they all say that they are lucky if 5% of all maxima injector cores are rebuildable. of those that are rebuilt and met spec, they fail about 1/2 the time.
Those are #s from GOOD rebuilders. the cheapo rebuilders that you typically find on ebay problem have a higher defect rate.
Because of remans I replaced 7 injectors on my first VE
What are these "rebuilders" replacing on the injectors? Are they trying to replace the coil?
save your money and do what I did:
http://web.syr.edu/~bvtran/injectors.pdf
I paid $60 at http://www.witchhunter.com/ to have it clean up. They're the same process those remanufacturers used. Just be sure your injectors resistance are ok before you proceed. Otherwise, head to the junkyard and pick some up and sent in for rebuilt.
6/Set: $339.50
Plus $90 Refundable
Core Charge
6/Set: $339.50
Plus $90 Refundable
Core Charge
Originally Posted by DaWifey's90
i'm torn between going OEM or bosch aftermarket.
OEM's have lasted me over 200K miles, but the bosch are cheaper and have a longer warranty...
arguments for either one from anyone else?
Hey, Personally I'd recommend the OEM injectors, in the case of what i went through, alot of aftermarket injectors seem to fail more quicker then the original oem injectors.
If you are looking at using your original injectors, have them cleaned and ohm tested to make sure they are working fine. Injectors after a long time need to be maintained and cleaned.
In most cases your OEM injectors are just fine
really?! how come they come with different warranties? it almost seems like it depends who you purchase them from rather than the fact that you're buying the same product.
but the part in the box is the same.
In most cases your OEM injectors are just fine :read:
there is no new aftermarket injector for 93 and newer maximas. they are all bosch/OE rebox
Cleaning them is what kills them, Nissan released a TSB recommending against cleaners in the tank, which are much less caustic than the ones used when rebuilding them.
so i may have killed my own injectors with seafoam?
really?....maybe i should take this to the fluids and lubricants forum...
by "per say" did you mean "per se"?
I wasn't an English major
hehe...neither was I...but i do speak the language...it's latin btw, not english...
heh..it's one of those useless pieces of information that was embedded in me in high school....and now i can't help myself...
If you have a failing OEM injectors, the route to go is reman OEM's. Not aftermarket. The term "Reman" may not be the most accurate, since no injector company replaces the coil. But extensive testing can be done to ensure the coil is in good working order, flow rates are balanced, and spray pattern is acceptable, filters, spacer, and o-rings are replaced.
The thing about mixing and matching OEM's and aftermarkets is that most likely you will have two different performing injectors. Coil response could be slightly different, spray pattern could be different, and even flow rates can vary.
Do a simple ohm check before replacing/servicing injectors. (clean connectors of corrosion first). If they are not between 11-13 ohm's the injector is most likely bad. Don't waste your time on a injector with bad ohm's. Send the rest to a place who does off the car injector service and who can provide replacements if needed. More extensive coil testing can be done to evaluate if the coil is still in good working order. After cleaning, sonication, flushing, and flow testing a determination can be made of which need to be replaced and which are in still good working condtion....then go from there.
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
