de-k injectors in 4th gen w/ stock ecu?
with all the 00VI swaps being done, figured someone out there has been there and done that ! just wondering how much richer the car is going to run, and what to expect until i get the greddy eu tuned.
ruin spark plugs ? burn heaps of fuel ? just looking for some personal experience and what i need to do with this setup until tuning?
You can get an AFPR and lower the FP ever so slighty, BUT dont bother until you check your a/f ratios. Stock is 259 and the DEk ones are 290 IIRC. Its not a huge difference, definetly not enough to foul the spark plugs. If anything the rich condition will slow you down, keep you cool, and pretty darn safe.
I plan to upgrade my engine for spring. Actually I have injen cold air intake, y-pipe, hi flow cat, 2.5 cat back mandrel bent and NGK iridium plugs.Other small things but not as important as these. I'm thinking about these parts:
-Pathy TB
-V-ACF2 with 24 pts corrections
-DE-K rails and injectors(290cc/min)
-FPR with gauge around 50 psi
-DE-K heads with cams
-00VI
I have a deal on a 64,000mi DE-K at 800$CAN around 600$US.
What kind of gains should I expect.Or with what I actually have, what would you guys do.Consider I wanna stay N/A and 3.0L...
Thanks for your support!!!
-Pathy TB
-00VI
-Pathy TB
-00VI
-Pathy TB
-00VI
I want to have another 'shelf engine' like the block,accessories that comes with it and internals. If the engine internals craps, I would have the internals to swap in the 3.0DE block. Imagine if we can stroke it with higher compression pistons, I would already have the the crank and bearings in the DE-K shelf engine.
Originally Posted by Ceasars Chariot
gtr a bit slower right ? so the difference in size is not enough to mess up anything short term.
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
