Just got Fast blinking LED turn signals. do you like them?
Old Dec 18, 2006 | 04:37 PM
OC guy's Avatar
2002 maxima se
I went to autozone and replaced my tail turn signal bulbs with LED RED 1156R. it was not easy to get those bulbs into the connector socket because the OEM1156 bulbs are a bit diffrent than new LED 1156R but i managed to push them in with force and they fit straight in. ok then i noticed that all of my turn signal bulbs have become quicker comparing to the stock timing and also are nice and bright LED. now they blink faster and produce more light because of new LED bulbs. in front i got silverstar amber 1157 they look better than any stock bulbs out there and they noticed bluish when off. anyway if any of you want to get fast blinking turn signals go with 1156R RED LED. you wont be disapointed. cost $18.00 heres the picture>>>
Old Dec 18, 2006 | 04:44 PM
greg84mk2's Avatar
looks interesting... does A/Z have other bulb sizes in this LED config?
Old Dec 18, 2006 | 04:46 PM
ktranne's Avatar
NOOB
yeah, that happened to me b4. Had it for 2 weeks then realizes it draws attention to cops so I got load equalizer.....
Old Dec 18, 2006 | 04:48 PM
OC guy's Avatar
2002 maxima se
i dont think cops should have any problem with quick blink. afterall we are using the red and amber lights?
Old Dec 18, 2006 | 04:49 PM
OC guy's Avatar
2002 maxima se
they got 1157 1156 and 194 for side markers.
The Law's Avatar
I R The Law
time to change your blinker fluid
put a load equilizer on cause fast blinkers are for ricers
Old Dec 18, 2006 | 05:25 PM
OC guy's Avatar
2002 maxima se
gotta wait till i get pulled over. lol btw where to get that load eqilizer and where do we put that? i have no idea!
Old Dec 18, 2006 | 06:15 PM
greg84mk2's Avatar
load equalizer? you mean some kind of relay that slows the flash intervals?
Old Dec 18, 2006 | 06:47 PM
MIXXMAX's Avatar
No, it's like a resistor which equalizes the LED's in a 12 Volt circuit. When you use LED's in a bulb socket/circuit, the amperage is so small that the car will think that the bulb is burned out. The load equalizer balances this load out like it's a regular incandescent bulb.
Old Dec 18, 2006 | 07:44 PM
n3985's Avatar
大陆弟弟
And no load equalizer = LED burning out much faster.
Old Dec 18, 2006 | 07:46 PM
irish44j's Avatar
retired moderator
fast blinkers are the very definition of RICE!
Old Dec 18, 2006 | 07:55 PM
OC guy's Avatar
2002 maxima se
how and where do we put that load equalizer device? i really like the look of LED but i guess the fast blinking can put me in trouble.
Old Dec 18, 2006 | 08:01 PM
MacGarnicle's Avatar
its easy - you're just adding the resistor to the circuit. You splice one end to the ground wire, and the other end to the... black wire? Something like that. Works as advertised though! you'll need one for each light.
Old Dec 19, 2006 | 08:01 PM
spencediggy's Avatar
they sell it on ebay...its called load resistor
http://cgi.ebay.com/ebaymotors/LED-L...4184QQtcZphoto
Old Dec 19, 2006 | 08:12 PM
OC guy's Avatar
2002 maxima se
^ thanks alot thats what i was looking for.
Old Dec 20, 2006 | 10:17 AM
bluedevil1550's Avatar
Does anything happen if you use LEDs for the brake lights and not the signals?
Old Dec 20, 2006 | 10:49 AM
OC guy's Avatar
2002 maxima se
it should work fine. i think load resistor is needed for turn signals only. i am going to replace the brake bulbs with led and will let you know.
Old Dec 20, 2006 | 11:20 AM
oldmanshirt's Avatar
I tried LEDs in my brake lights and everytime I'd hit the brakes, a red bulb in the instrument cluster would come on (the one that tells you you have a brake light out). I got tired of that real quick, but when I put the originals back in, the brighter filament on one bulb was out. I got a new bulb and it worked fine, but it was kind of a pain.
My $.02, since you asked, is that LED replacement brake or turn signals look extremely cheesy unless you get them custom made to fill the whole housing like a few ppl on here have done.
Old Dec 20, 2006 | 01:11 PM
greg84mk2's Avatar
Ive been doing some research since finding this thread, and came across this site:
http://www.superbrightleds.com/mini-wedge.html#
It discusses the load resistor and explains that not to expect the LEDS to be brighter than regular filament bulbs unless one particu;ar style is chosen.
I have no affiliation with that site and Ive never bought from them, so this isnt a testamonial for them... just good reference.
Old Dec 20, 2006 | 05:11 PM
Derrick2k2SE's Avatar
They may not be illegal but they can still get you pulled over. A cop will see them and think you have a bulb out and pull you over. You may not get a ticket for the blinkers but the cop will probably take a hard look at the rest of the car. Who needs the hastle? Besides, they do look ricey.
Old Dec 20, 2006 | 09:44 PM
i have the same problem with the LEDS, even though i have the load resistor, i've haven't found time to install them. i don't get hassled by the cops and i live with the best of the worst cops....NYPD!!!
if ur getting LEDS, get the refracting LEDS 7740/7743. they definitely shine the entire taillight at nite.
pears
Sep 18, 2015 05:25 AM
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
LtLeary
Sep 14, 2015 12:33 PM
