Sponsored by:
Sponsored by: CARiD
technosquare ecu question
Old Dec 23, 2006 | 05:39 PM
3.5altman's Avatar
Sup guys i got a technosquare ecu from friends wrecked car, We have the same year car and engine and when i swapped ecu's with him the car wouldnt start. Im guessing its the immobiler, andbody know of a way i can get around this, if so which is a good low cost way...lol
Old Dec 23, 2006 | 06:05 PM
NmexMAX's Avatar
dot dot dot ...
Take to Nissan, they can fix it.
Old Dec 23, 2006 | 06:14 PM
3.5altman's Avatar
thanks homie
Old Dec 24, 2006 | 12:26 PM
Larrio Motors's Avatar
Boss Chen Industries
technosquare can also duplicate your immobolizer information... probably for a cheaper price than the Nissan dealer also
www.technosquareinc.com
Old Dec 24, 2006 | 04:49 PM
3.5altman's Avatar
yea well im gonna try and price for both only problem is i wonder if i take it to dealer for this well it mess the technosqaure flash up
Old Dec 24, 2006 | 05:06 PM
NmexMAX's Avatar
dot dot dot ...
It wont 'mess it up'.
Old Dec 27, 2006 | 02:48 AM
3.5altman's Avatar
hey guys would this work???
How-To RESET the Nissan Vehicle Immobilizer System(NVIS) on a 2K-2K1
Once a BAD key has been used CONSECUTIVELY five or more times to unsucessfully start the engine, the ECU enters "LOCK MODE".
If the ignition key is in the "ON" position and the security indicator LED(on the clock) is ON(doesn't blink), the NVIS is triggered by one of numerous possiblities but it's probably the chip in the key.
There are TWO possible solutions:
1)Try to escape from LOCK MODE,MUST USE A GOOD KEY and perform the following:
a.Turn ignition switch to "OFF".
b.Turn ignition switch to "ON" with GOOD key.(Do NOT start engine.) Wait 5 seconds.
c.Return key to "OFF".
d.Repeat steps b and c TWICE(total of three cycles).
e.Start the engine.
2)If 1) didn't work it MUST be towed into Nissan to have ALL the keys wiped and reprogrammed with the ECU.
Old Dec 27, 2006 | 07:44 AM
NmexMAX's Avatar
dot dot dot ...
You tell us.
Old Dec 27, 2006 | 07:52 AM
MaxBlack97's Avatar
I thought technosquare doesnt do anything 4 Nissans anymore?
Old Dec 27, 2006 | 07:54 AM
NmexMAX's Avatar
dot dot dot ...
4th gens no, Nissans yes, defiantely YES, almost if not 100% exclusively.
Old Dec 27, 2006 | 10:03 AM
eng92's Avatar
Procedure 1 works on an A33B.
I found that out while trying to determine how far away the key could be from the NATS module and still allow the engine to start.
Old Dec 27, 2006 | 05:41 PM
3.5altman's Avatar
i called nissan and they want 94 bucks to reset the immobilizer
Old Jan 8, 2007 | 11:51 PM
3.5altman's Avatar
aight homies i found someone to do the immobilzer for $25, but i got a quick question. I have an 02 altima 3.5 5-speed ecu code 2E, the ecu came out of an 03 altima 3.5 5-speed ecu code 2F. do you guys think there will be a problem switching these ecu's. I know there the same car and ecu but im just curious?
Old Mar 25, 2007 | 06:34 PM
TIEL240's Avatar
I have this problem but sometimes the car starts fune and then sometime the immobilizer(light is solid red) and then it won't start. If i let it sit a couple of days it will work agian for 2-3 days,took it to the dealer and because they didn't find any codes they said the factory alarm was fine!!! what gives?
e.Start the engine.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
