Fog lights not working after reseting the ECU
Hi guys,
2 days ago I reset my ECU using the gas-pedal method. After that my fog lights went off and it doesn't come back on no matter what I do.
I'm not too sure if it has something to do with the ECU rest. Anyone has any idea?
Originally Posted by xoomer.com
Unplug your battery for over 10 minutes. This is a hard reset and will reset your ECU again. Might help
Originally Posted by utas424
I could do that but i'm afraid it might screw up other things. Last time I did that to my 02 Max, the sunroof stopped working. I had to reset it to make it work. I'm not sure with 04 what other things might stop workign if I disconnect the battery.
Originally Posted by madmik
A few times, I unplugged the battery for many hours and I only had to reset my settings via the screen. Everything still worked fine, as it should have. Car may behave different until throttle position and idle air mix are 'learned'.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
