Suspension mod Question
Old Dec 28, 2006 | 10:25 PM
StillenMax80x20's Avatar
What to do?
I hate the fact that i live in an area where pot-holes are "deemed" fixed by adding speed bumps (pun intended). But I am also bored with the way the stock Y2k Maxima handles!
As far as over all responsiveness and effective yet mild mannered upgrades go; would I be better off:
A) Staying stock (boring)
B) Adding frame stiffeners. the RSB, RSTB, LTB, FSTB's and or FSB's (or whatever)
-or-
C) Changing Spring/Strut setup.
Also, what is most effective combination of B without changing springs
I really am weary of option C because I think the car is bad enough up here in N.E. MA
Anyway, thanks for taking the time to read this and thanks for any input.
Old Dec 28, 2006 | 11:11 PM
zero2sixtyZ's Avatar
You embarrass me.
B: In rate of effectiveness, i'd say RSB (based on .org readings), LTB Stage 2, FSTB. RSTB was said to do next to nothing. I have LTB 2 and FSTB. The LTB2 made a huge difference in turning and chassis strength. It does decrease your overall ground clearance by a little bit, but it is between the wheels so you shouldn't scrape anything unless you are slammed.
C: I personally will be going Eibachs or H&Rs w/ Illumina shocks. Decent drop, somewhat close to stock ride quality, but i've heard eibachs are more aggressive.
If you are scared to drop it, go with the bars at least. Adding ES bushings should help as well.
Old Dec 29, 2006 | 07:10 AM
thanks ZERO-60Z, helps how is side to side affected at greater speeds with LTB2 and rsb?
Old Dec 29, 2006 | 07:16 AM
SoonerFan's Avatar
Cletus
i would suggest a combo of both B and C
FSTB, RSB, and LTB
lowered (i like my H&Rs, better handling but not to low)
Old Dec 29, 2006 | 11:31 AM
oldmanshirt's Avatar
I'm like you, StillenMax, I think the SE rides rough enough stock. Although I'd like to do something about the uneven stance, lowering just doesn't appeal to me from a ride standpoint. I just plan on adding a Stillen RSB and a FSTB (which will hopefully eliminate or at least limit body roll) and calling it a day.
Old Dec 29, 2006 | 02:17 PM
ktranne's Avatar
NOOB
which bushings recommended?
Old Dec 29, 2006 | 05:21 PM
i think 0-60Z reccomended Energy Suspension Bushings. I am also no doubt adding a RSB, I HAVE a FSTB and it did really make a difference! But as far as lowering goes, i would sooner buy wider rims/tires. Any handling package on EVERY car changes tire width. Period.
Old Dec 29, 2006 | 05:39 PM
What brand did you get? I like the Stillen but it's crazy expensive. The Vibrant doesn't look as cool but is only $60 instead of $150
Old Dec 29, 2006 | 09:31 PM
I bought a 30 dollar e-bay one
I have a few corners I tested it on, i'm sure if I took it off I would notice, But maybe not
Old Dec 29, 2006 | 10:27 PM
so how tricky is a FSTB to install? I'd love to do both it and the RSB myself. I know I'll need a jack and some stands but other than that, how much is invovled?
Old Dec 29, 2006 | 10:57 PM
You embarrass me.
I don't have RSB, but based on the .org readings, everyone has said it stiffened up the rear, which is definitely one of the weakest points in our handling. I installed the FSTB myself, and could tell a difference, but the lower part of the car was still too loose. Thats where the LTB2 came in. Stiffened up the lower part to 4 points, which made a huge difference. Side to side is noticeable with less flex and better stability. Once you even hit a bump, you will feel the car flex less and be more stable. RSB is probably next for me, but springs/struts are going soon (62k), as well as tires.
Old Dec 29, 2006 | 11:03 PM
interesting, but that doesn't really answer my question.
Old Dec 30, 2006 | 12:01 AM
SoonerFan's Avatar
Cletus
honestly, the FTSB by itself doesnt really do much (besides look cool in your engine bay). the combination of FSTB, RSB, and LTB is a huge improvement
Old Dec 30, 2006 | 12:03 AM
SoonerFan's Avatar
Cletus
FSTB is very easy. you just remove the 6 nuts from the strut towers and install the brace.
as far as the RSB, on a car with stock suspension, it can be installed with the car on the ground. however, it makes it easier if you have ramps. i've installed about six RSBs and it takes about an hour to do.
Old Dec 30, 2006 | 12:30 AM
Thanks for the help, that sounds alot easier than I was expecting
2kmaximel
Sep 9, 2015 07:35 PM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
