help need to disarm car alarm but....
my door handles are shaved and my factory key fob wont work. I have pulled the fuse and I can't get my car to start, the alarm has disarmed the starter. What can i do.
Slim Jim? Get in the car and unlock it via the door switches? Idk. Just dont get arrested.
Also, you could take it to a place that does alarms. That way, they may be able to disarm it or something.
Try doing this. If you can open the driverside door, open it. Leave it open. disconnect the negative part of the battery cable. In most cases by doing this, it resets the alarm. Most of these alarms also disables the fuel pump so that would also cause the car not to start or even in some cases the engine to even roll over. Get into the car close the doors. lock the doors and try starting the car. I hope this works.
I don't even need the factory key fob, my doors open fine but when i open them with the shaved door remote but the alarm goes off and i have to pull the fuse to get it to stop beeping. and can't get the car to start. I have to reset my ecu with the screwdriver and then put the fuse back in to start the car.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
