Rear camber problem
Rear camber problem
I just got my 95 Maxima back from the alignment shop and my rear camber was negative. -1.0 (left) and -1.1 (right). What can cause this? I do an aftermarket RSB on the car that I tightened while the car was in the air...I don't know if this would really affect anything but just thought I would mention that. I am lowered several inches on Ground Controls and AGX's. Why would my rear camber be negative? What would cause this problem? Thanks for any help.
I would remove the rear wheels and tighten them again with a torque wrench. Then take the car to a different alignment shop for a second opinion. Sometimes those alignment machines are off. Did you add something to the rear lately, like wheel spacers?
that could be the case. This is a pretty busy shop though so I imagine they would keep on top of their equipment. It does seem odd to me that the camber readings on each side of the rear were ~ the same. It would make more since if one side was messed up from being in a wreck or something. The car does track straight since the alignment so whatever they did in the front seems to be right.
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
Total toe-in distance, in millimeters
-3 Minimum
+1 Nominal
+5 Maximum
Total toe-in angle (left plus right), in degrees
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
There is nothing wrong with your rear camber, it's right on the money.
Originally Posted by njmaxseltd
Your car is tracking correctly.
oh ok cool. I did not know that and I guess the guy at the shop did not either because when I went to pick the car up he circled the two rear numbers and was telling me that they were off. Oh well....that's good to know there is nothing wrong.
I would be tempted to go back to the shop and ask the guy where he got his figures. I would not trust that he knows what he is doing on a Maxima.
Huttig2009
Sep 25, 2015 03:31 PM
for the machine being off. That happens a lot.
