Hazard and Defrost lights out.
The Hazard and Defrost lights do not illuminate with the rest of the cabin lighting. Are they on the same fuse? A friend with a '96 had a similar issue but didn't really care so I didn't either, until now.
If the bulbs are burnt, you can get bulbs at radioshack that are a perfect replacement. I know cause I just did mine yesterday. I decided against led cause I don't want to deal with soldering resistors.
My bulbs were both out, but I hit a good sized crater in the road, and the thump somehow instantly managed to knock them back on
. I know they're probably going to go out again, so I figure i should probably change them out.
Originally Posted by 2pb
can you give any more info on this, like the exact radioshack part #? thanks.
. I know they're probably going to go out again, so I figure i should probably change them out.Part number is Model: 272-1092
I should have taken pictures when I done it. Anyway unhook the old bulb's prong from its rubber housing with a tiny screwdriver or a pin. The radioshack bulb's prong are flexible enough so that you can bend them into the rubber piece just like the factory bulbs. Transfer the old blue bulb cover to the new bulb and your done. If it is not clear what I am talking about let me know. I'll take it back out and take some pictures.
Sure. http://www.radioshack.com/product/in...entPage=search
when I removed my OEM radio, I "fried" ( don't knwo how) the lights for Digital climate, rear defrost and hazard switch..
I purchased replacement bulbs for the digital climate control ( $10/each at dealer)...
but thanks Fithos, I will go buy the bulbs at radio shack/the source to replace hazard and rear defrost...
thanks again
thanks again
I'll try that, thanks.
Really don't want this thread to go off topic, but it's just a great photo and what I and many other new yorkers wish would be rebuilt in that area. If you, or any of the moderators find it inappropriate for whatever reason, PM me, and I'll change it.
And fwiw, I completely agree, they should've rebuilt that area to look atleast from the skyline exactly the same, by changing it and making the buildings smaller, in a way were saying the terriorists won. So no, no problem here
thanks again
thanks again
BTW those micro bulbs from radioshack also works for the ashtray light too if it is burnt out (like mine).
sctludwig
Sep 1, 2022 01:32 PM
Maxima30
Sep 7, 2015 06:13 PM
