Driver Side Sun Visor Lights
Old Jan 13, 2007 | 07:53 AM
HarrisH's Avatar
The lights that go on when you flip open the cover on the driver side are not working on my car. It's a 97 GXE. My BCM is also fried because I tried to put a LED in the ring light and the neg. and pos. touched and the Dome light doesn't work when the doors are open. The passenger side sun visor lights do work, any input or advice please? Thanks.
Old Jan 13, 2007 | 08:06 AM
HarrisH's Avatar
Anyone????
Old Jan 13, 2007 | 10:30 AM
2da mizzax's Avatar
i can sell you a BCM.
Old Jan 13, 2007 | 11:42 AM
HarrisH's Avatar
What's part # on BCM and price, what year did it come out of and how many miles were on that car?
I figured out my sunvisor problem, it's the actual sunvisor that's bad
Old Jan 13, 2007 | 11:51 AM
2da mizzax's Avatar
i have 2 (from 2 different years) couldnt tell you how many miles and when i get the chance i will give you the part number. will have to be matched up with the plug pattern.
http://forums.maxima.org/showthread.php?t=505939
i believe they are 97 and 98.
Old Jan 13, 2007 | 11:59 AM
eng92's Avatar
If the only problem you are having is the ignition key light and the courtesy light, it is probably not your bcm.
Are your interior spot lamps (between the visors) working? How about your trunk lamp?
Those four sets of lights run through fuse number 26 (7.5A).
That is why they have fuses; so you do not ruin expensive components or start fires when you are fooling around with vehicle electrical systems without first disconnecting the battery.
Old Jan 13, 2007 | 05:26 PM
HarrisH's Avatar
The MAP Light is working, Glove box light is working, trunk light is working. Door panel courtesy lights are working.
I know for a fact that the cigarette light, ignition light, and dome light with doors being open closed works from the BCM. A buddy of mine had a similar problem, replacing the BCM worked for him.
Old Jan 14, 2007 | 01:29 PM
supervinn's Avatar
i have 2 sun visor for sell 20 + shippin all yours.. perfect condition workin light
Old Jan 14, 2007 | 06:05 PM
HarrisH's Avatar
What color? I only need driver side, take a few pics I'll take it.
vingodine
45
May 21, 2016 12:46 PM
boomerbrian
Nov 8, 2015 05:10 PM
rtirbany
Sep 8, 2015 11:46 AM
