Changing front crank seal
Old Jan 14, 2007 | 07:48 PM
dgeesaman's Avatar
Maintenance Monster
Mine's starting to seep a little oil, so I intend to pull the crank pulley and change this.
I figure my electric impact wrench should loosen the nut, I might need my 2 jaw puller to pop the pulley free, and then I just pry out the old seal and tap in the new one.
Is it really that simple? Any tips appreciated.
Dave
Old Jan 15, 2007 | 05:11 AM
njmaxseltd's Avatar
Yes, it's kind of that simple. Your going to need a strong impact to get the thing loose. Your electric gun might not cut it.
Old Jan 15, 2007 | 06:36 AM
dgeesaman's Avatar
Maintenance Monster
My electric does 320ft-lb when fully charged. I should probably work with some penetrating oil first.
The FSM says to tighten to 30ft-lb, then another 1/6 of a turn. Dunno exactly what torque that will be, but probably reasonable.
Dave
Old Jan 15, 2007 | 07:25 AM
sky jumper
what kind of elect impact do you have? do you use it for things like removing lug nuts? I ask because I bought one a while back that was rated for 275ft-lbs and it could not even spin off lug nuts so I returned it.
anyway - please keep us posted on your results. I too might try to replace that seal.
Old Jan 15, 2007 | 09:41 AM
dgeesaman's Avatar
Maintenance Monster
Ingersoll Rand IR 2530. http://www.irtools.com/IS/product.asp-en-2868.
It easily does lugnuts on my truck, and I trust it will handle axle nuts too. I cry tears of joy when I think about it. (I don't have space/neighbors for an air compressor)
Dave
Old Jan 15, 2007 | 10:07 AM
sky jumper
a few more thoughts on this...
- I think you have to remove the crank pos sensor before you pull the pulley.
- I've never used a seal puller before so I don't know how they work. but you do no want to just "pry" at the seal with a screwdriver though. what you need to do is punch the front edge of the seal with a hammer & punch (or slotted screwdriver) so as to compress its circumference ever so slightly. this will make it much easier to remove. or just get the proper tool.
kjlouis
Nov 24, 2018 06:09 AM
305head
Aug 26, 2015 09:03 PM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
