Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
What is the difference in GC's Tokico and KYB?
Old Feb 8, 2007 | 05:30 AM
cardana24's Avatar
Blown
I am thinking about changing my strut set up on my Ground Controls. I would like to know what the difference in the GC's is, since they are sold for specifc applications. I am thinking about switching from AGX's to Illumina's. Anyone know?
Old Feb 8, 2007 | 06:55 AM
d00df00d's Avatar
Old enuf to pick his own gears
AFAIK the only difference is in the inner diameter of the sleeve. I could be wrong, though...
Old Feb 8, 2007 | 07:14 AM
cardana24's Avatar
Blown
what does AFAIK mean? I see a lot of people use that but I don't know what that means.
If that is the case do you know which struts are bigger? The reason I ask is because if the sleevs I have will fit over the Tokico's then that will work, because I wrapped mine with duct tape instead of using the rubber inserts, so I can just wrap more/less tape to make them fit snug.
Old Feb 8, 2007 | 07:36 AM
d00df00d's Avatar
AFAIK = As Far As I Know.
No idea about the damper body sizes. I'm sure someone knows, though (or at least knows where to look)...
Old Feb 8, 2007 | 09:18 AM
The Law's Avatar
I R The Law
Kyb front stuts can be adjusted on the top while the rear struts you have to adjust them by going under the car. Somebody correct me if I'm wrong on that. The Tokico are adjustable on the top.
Old Feb 8, 2007 | 09:35 AM
A33 VQ30DEK's Avatar
you are correct!
Old Feb 8, 2007 | 10:34 AM
cardana24's Avatar
Blown
thanks for that info. but I am not so much concerned where you adjust the damping. I am more interested as to if there are differences in the GC parts.
Old Feb 12, 2007 | 08:59 AM
zippyflu's Avatar
by kyb u mean the AGX?
Old Feb 12, 2007 | 09:01 AM
cardana24's Avatar
Blown
yes that is what I mean. Do you know how the fitments vary from Ground control on these two struts.
doctorpullit
Dec 12, 2015 09:39 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
maxima-junky
Oct 7, 2015 06:13 PM
