Suspension question- Alignment causing tire wear?
My Max is having a bad time with tires. I've bought 2 sets of name brand tires for it in the last 3 years. what's happening is that the inside of the tires are wearing out faster then the rest of the tire. At first I thought it was alignment but having it aligned 2 times already it still wears them uneven. I've checked tire pressure and rotate every 5000 miles.
My thought is this, the car was orgianally owned by my grandma. She didn't drive it all that often so it would sit for months on end only being started but not moved. could something have happend to the springs? could they have worn to where the wheels are constantly tilted?
Ask for a printout of the specs.
Post them here and compare them with the "normal" specs, as listed in the sticky thread.
Prosper.
i think you there might be a chance that your suspention parts are bent and or damaged, this is pending the shop knows how to do an alignment and the did not just set the toe and go.
If they did it right and pulled everything within specs then you have something bent there that is causing your alignment to be off while in motion. for an experience tech it would be fairly easy to see.
Do what phenryiv1 said and get it at a free check place, look at the print. if they did the toe and go thing. your total toe should be like like 0.03" or less and your camber/ caster should be off the wall.
on the front end check, for bushings, balljoint, tie rods, etc wear. If everything isn't in acceptable shape, your alignment won't hold for very long.Sad thing is on the A32 the only thing adjustable from the factory is front toe, rear is completely fixed and front caster/camber aren't changeable. Camber can be nudged in the area of a hundredth of a degree by playing with the strut-to-knuckle bolts, but a camber kit (or plate, even better) is the only real way to adjust our camber.
if he went to a proper shop in the first place they would have done a chek on the front end while aligning the car. they always do this to upsell and see if there are any other probems they can charge you for.
i say get ur alignment done at another place because the one you are going to is doing something wrong
ps. i just aligned my car myself n now it drive great
if your not lowered... it sounds like worn out parts...
Either way... inside tire wear is usually caused by camber... can't adjust on our cars. Unless you have more of a feathering pattern. Than it is a toe problem.
Mar 12, 2020 12:06 AM
