hard to shift into gear
Old Mar 5, 2007 | 09:27 AM
Zshopa's Avatar
hey guys i just put a new trans in my car, and its really hard to put it in gear sometimes, any ideas? i know its vague but i just put it in yesterday and havent really felt it out yet.
Old Mar 5, 2007 | 12:52 PM
96max_manSE's Avatar
driving so slow aint easy
its not broken in yet its a new tranny so drive it easy for awhile and start working them gears hopfully you changed the clutch too if not you should
Old Mar 5, 2007 | 12:55 PM
pmohr's Avatar
No more Maximas...
Did you replace the clutch as well? What type of gear oil did you use?
Old Mar 5, 2007 | 01:26 PM
Zshopa's Avatar
yes i changed the clutch and i used amsoil GL4
Old Mar 5, 2007 | 02:22 PM
95BLKMAX's Avatar
is it a new transmission as in BRAND new from factory, or new as in one to replace your old one?
Did you happen to (for any reason) mess with the shifter bolts? I know when I tightened my shifter's throughbolt at the bottom on the control rod shifting took alot of effort.
Anyways, new or used (assuming that its in good condition), give it a few days of working through the gears.
Old Mar 5, 2007 | 07:10 PM
Zshopa's Avatar
its used but its fully rebuilt, i did have a lot of trouble tightening those screws, correct me if im wrong but theres 2 of them on the bracket.
Old Mar 5, 2007 | 09:24 PM
soseihin's Avatar
So, just how hard is really hard? But it's not really hard alll the time? These other guys are probably right, you may just need to break it in. Have you tried double clutching? That'll let you know if it's the synchros. Which I think are kind of a little weak. Or maybe the gears too are burly. Either way...
Old Mar 6, 2007 | 02:57 AM
dgeesaman's Avatar
Maintenance Monster
Is it hard to shift quickly, or hard to shift standing still?
Dave
Old Mar 6, 2007 | 06:04 AM
the_3d_man's Avatar
did you rebleed the clutch? using both bleeder valves
Old Mar 6, 2007 | 07:01 AM
Zshopa's Avatar
no didnt bleed the clutch, is it necessary that i do? also sometimes its easy to go into a gear and sometimes i cant quite get it in very smoothly
Old Mar 6, 2007 | 07:46 AM
soseihin's Avatar
On both the up and downshifts?
Old Mar 6, 2007 | 08:00 AM
95BLKMAX's Avatar
OT- soseihin, "Car: 1999 Super Black A32 with a VQ30". If you have a 99 its a given that you have a VQ30, lol. You should only need to specify the engine if its a swap, like a DEK or 3.5 motor.
OK back on subject, Worse come to worse, does this rebuilt tranny have a warranty on it?
Old Mar 6, 2007 | 09:36 AM
KRRZ350's Avatar
If you don't have a leak and you removed the slave-cylinder with out disconnecting any lines then no
Old Mar 6, 2007 | 10:21 AM
Zshopa's Avatar
thats what i thought, ok thanks
it seems to have gotten a little smoother but still rough on some up shift and down shifts and reverse and 1st seem to be the hardest
Old Mar 6, 2007 | 09:12 PM
soseihin's Avatar
Geez... everyone's a critic.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
