hard to shift into gear
hey guys i just put a new trans in my car, and its really hard to put it in gear sometimes, any ideas? i know its vague but i just put it in yesterday and havent really felt it out yet.
is it a new transmission as in BRAND new from factory, or new as in one to replace your old one?
Did you happen to (for any reason) mess with the shifter bolts? I know when I tightened my shifter's throughbolt at the bottom on the control rod shifting took alot of effort.
Anyways, new or used (assuming that its in good condition), give it a few days of working through the gears.
OT- soseihin, "Car: 1999 Super Black A32 with a VQ30". If you have a 99 its a given that you have a VQ30, lol. You should only need to specify the engine if its a swap, like a DEK or 3.5 motor.
OK back on subject, Worse come to worse, does this rebuilt tranny have a warranty on it?
no didnt bleed the clutch, is it necessary that i do? also sometimes its easy to go into a gear and sometimes i cant quite get it in very smoothly
Originally Posted by KRRZ350
If you don't have a leak and you removed the slave-cylinder with out disconnecting any lines then no
thats what i thought, ok thanks
it seems to have gotten a little smoother but still rough on some up shift and down shifts and reverse and 1st seem to be the hardest
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
fx4five
10-01-2015 04:58 AM
