00VI swap, butterfly valves in LIM?
I am getting ready to do an 00VI swap on my 95 GXE. I bought a rear valve cover and a LIM from a DE-K car. There are butterfly valves on both sides of the LIM, what am I supposed to do with those? I was thinking I should cut them out? Is there an easy way to take them out if that is what I am supposed to do? Any advice would be appreciated.
Originally Posted by gtr_rider
In the stickies theres 5-6 threads listed showing how to do a complete swap.
Originally Posted by cardana24
I am aware of that but I did not see where any one mentioned anything about what to do with the butterfly valves in the LIM.
They are indeed Cali swirl valves (for emissions purposes). The link gtr_rider provided you should tell you how to get rid of them. Don't repeat ghostmax301's mistake (no offense, buddy, just being helpful to him) and be sure to clean out the LIM well before you JB weld the holes.
on the link that GTR provided, he says to cut them out and then plug the outside holes with JB weld. Is this correct? Did I miss something? Do I have an extra set of butterfly valves/do I have a cali spec LIM? I have them on both sides of the LIM.
the valve plates have 2 screws holding each plate on, take those screws out and remove the plates...i believe it might be 2 screws, one on the front runners, one on the back, once you take those out, take apart the mechanism on the end of the LIM, and everything should pull out.
No problem tatanko, My only mistake was not cleaning the oil out of the holes before filling them with JB weld, so it didnt stick to well..
alright, I just took the butterfly valves out. It was not hard at all. After the flappers were out I just took out one screw holding each rod in, then poped off some c-clips and the rods slid right out. After I got the rods out I cleaned out the LIM. It had plenty of carbon build up, and I went ahead and scrubbed down the out side with some Pomolive. Everything is drying now and I would like to do the JB weld tomorrow. My question is what all do I JB weld? More specificaly I know I need to do the two holes where I pulled the rod out of the LIM, but do I also need to JB weld the holes going through each runner? Does that make since? I assume not JB welding the holes between the runners may cause turbulance? Any advice?
I put JB weld wherever there was a hole including inside the runners when i did a DE-K swap. I then smoothed it down with a dremel and grinding bit and made it perfectly flush with the runner.
I meant to say JB stik.
It's MUCH easier to work with in this case.
well I just got the stik and I am going to go down and work on it in the basement. I have used two part epoxies before and they set up hard as a rock...so I assume this will work well too. I read in the directions that it is easier to use if your fingers are damp, this is something that I always noticed with other two part epoxies, they do not stick to your fingers as much if your fingers are a little wet.
everything is setting up right now. I am going to give it about another half an hour and go down and start sanding it. So far everything is looking just fine. The only thing I was having trouble with was getting air pockets when filling the holes between the runners...hopefully everything will work out just fine.
Originally Posted by Project323
just a warning... JB weld + oil + vibrations =
JBweld is good, but if there's a chance for the stuff to get into the engine... i would hesitate to use it.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Damp fingers will help tremendously.
