Need Help replacing rear brake pads!!!
I'm trying to install my new brake pads and rotors. I was able to replace the rotor but I can't seem to compress the rear calipar piston. I tried useing a C clamp but it's not working. BTW I didn't have any problems changing the front rotor/pads.
Does any one know how to compress the rear drivers side calipar?
Thanks in advance
Blade
Thanks in advance
Blade
Thanks in advance
Blade
Thanks in advance
Blade
You have to turn the pistons clockwise while pushing them in. They make a special tool for the job which I think runs about $10 but regular needle nose pliers do the trick. It only took 3 or 4 turns when I did it. Here is the tool in case you're interested:
KD #3163 Disk Brake Piston Tool
http://www.mytoolstore.com/kd/kdbrak07.html#3163
(Credit goes to Daniel B. Martin for providing this part in another thread)
Originally posted by ejj5875
You need to screw the caliper in using a set of pliers or something similar. Using a c-clamp will only fight that screw.
Blade
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
