AC system not working.
Old Mar 28, 2007 | 04:22 PM
goon9's Avatar
So I swapped in a r134 compressor, condensor and drier.
Put in a good ammount or freon but the dang compresor Will not kick on. Relay and fuse is good. Whatever supplies the low voltage to the relay isn't doing it.
Where do I look now?
And I know I have enough freon to not trip the low pressure vlave.
Old Mar 28, 2007 | 04:56 PM
goon9's Avatar
I even swapped out the climate controls to test. No change.
Old Mar 28, 2007 | 05:07 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
did you check the voltage across the 'coil' of the relay? also i wouldn't think that your new compressor's clutch is a dud right off the bat, but maybe it is.
Old Mar 28, 2007 | 05:20 PM
DanNY's Avatar
Ad·min·is·tra·tor
how much freon did you add? you can't really guess at it.
did you pull enough vacume and see if the system is fully sealed and dry before adding freon?
if there's not enough freon the compressor will not kick on....i'm sure if there's too much you don't want it to click on since it'll grenade the compressor.
Old Mar 28, 2007 | 05:33 PM
internetautomar's Avatar
mod or sell?
have you checked the pressure switches?
Old Mar 28, 2007 | 05:37 PM
goon9's Avatar
I drew a 30psi vaccuum for 20 minutes and it held over 30 minutes, at which point I decided it held good and was ready for freon.
I even jumped out the compressor and the clutch and everything works. Thats how I was able to charge it. And I brought it up to 34 psi.
How do I go about checking the pressure switches? ohm them out?
Old Mar 28, 2007 | 05:48 PM
mod or sell?
check for continuity on them
IIRC they are both N.C. and open when the pressure goes up for one and down for the other.
you could also bypass them one ata time to see if it trips the system on that way
Old Mar 29, 2007 | 02:53 PM
goon9's Avatar
I have cont. on the dual pressure switch on the drier. Where is the other one?
Old Mar 29, 2007 | 04:11 PM
mod or sell?
did you check both sides of the switch?
(HA-68 in the FSM)
as you pointed out it's a dual pressure switch, so it serves the function of 2 switches.
also check out the relay for possible malfunction
Old Mar 29, 2007 | 05:04 PM
goon9's Avatar
(HA-68 in the FSM)
I quess I'm unlcear how to porperly check it. Relay is good.
Old Mar 29, 2007 | 07:17 PM
mod or sell?
I'm unsure how to check it myself. that's why I pointed to the page in the fSM.
you do have the pdf of it don't you?
Old Mar 29, 2007 | 07:32 PM
goon9's Avatar
I do, it's not real clear to me.
Old Mar 29, 2007 | 08:07 PM
mod or sell?
it's not clear to me either.
maybe I'll pull out my hardcopy and read it through.
I have an easier time reading hardcopies than computer files
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
