HOW TO: ADD HEATED SEATS & Interior Overhaul
Tools needed
-wire strippers
-wire grounding kit
-MINI add a circuit (can be purchased from autozone)
-zip ties
-electrical tape
PARTS NEEDED
-heated seats from a Nissan maxima or infinity I-30
-OEM switches
-OEM wire harness
The overall install was a lot easier than I anticipated. Thanks to WIZARD and POOWILL for helping me out for they made everything 100000x easier. First off you want to get a hold of some heated seats from a junkyard or somewhere and hopefully they work. With the seats you also want to cut out the wire harness from the factory that runs under the carpet, along w the switches and wires that run to the center console.
There are 2 plugs underneath the seats. One for adjusting the seats and another for the heat. You can pretty much figure out what wires are the heating element ones from following them from inside the console.
There is only one wire that runs to the fuse panel, and there should be 4 black ground wires all together. .
Cut the ground wires from the rest of the harness at a considerable length depending on where u plan on grounding them. (I grounded mine under the console)
Other than the 4 grounds the only wire u should have to cut is the power wire which i cut all the way as close to the fuse panel as I could. This wire was white with gray dots.
U should now have your wiring harness separated.
Basically you are going to put the same harness back into your car the way you took it out.
connectors that will go to the switches on the console^
You will have to snake the power wire under your carpet from the console all the way down the side of your drivers door. The door panels will pop off if you give them a pull from the edge.
Once you have all your wires run, ground all 4 black wires under the center console,
(the console is removable by popping out the trim around the shifter than removing the two screws in the front and then two screws on the outsides in the rear.
The power wire which u should have snaked behind ur dash to your fuse panel needs to get power, so use the add a fuse and crimp the power wire into the provided add a fuse insert. Remove the MIRRORS fuse on the left of your panel. It should be under ACC, and this will only allow power when the ignition is on. Take the add a fuse and add two 10 amp fuses into the slots, and plug back into the MIRRORS fuse spot.
The other wires u should have ran under the carpet out through the power wire hole like so
Add the switches to the console by popping out the coin holders. Mine popped rite in since I have a 96 console
Now before reinstalling the center console, make sure the 4 black wires are grounded good, and the wires are correctly ran the right way. I taped mine to the other wire harness to keep them out of the way.
new seats
-wire strippers
-wire grounding kit
-zip ties
-electrical tape
PARTS NEEDED
-OEM switches
-OEM wire harness
new seats
Put everything back together now that you have all the wires ran. Install your new seats and test everything out. My switch lights didn’t light up so don’t panic if yours don’t. im gonna add LEDS to match the rest of my interior in the future.
I also redid the door panels which wasn’t too bad and swapped all seatbelts, and trim pieces.
Hope this helps some of your guys out. Once again special thanks to THE WIZARD (James)
Sorry If the write up is a little bad. im still hurtin from thursty thurs. If you have any Q’s shoot me a pm and ill help u out.
Peace
-nick
BTW i got black door panels and black interior parts if any of you guys are interested before i post a thread in the F/S section
Peace
-nick
i'm just about to do this. i have heated seats installed and the switches ready to go but i thought that the harness was under the carpet somewhere. this will help a lot. nice write-up! you will probably get a PM from me in the near future.
and lol at the Everclear in the backseat? haha
Originally Posted by Cdg2125
congrats on the install. Not feeling the black and tan tho. Big color clash IMO. Do you have a interior light that isn't blue? haha. Again, glad to see the install went ok.
thanks for the compliments guys
Originally Posted by phenryiv1
A black center console and black steering wheel woudl really finish it off better than the brown.
JMO. Other than that, the car looks good. I'll try to add this to the stickys.
QUESTION-i know u wanan sticky but wont the pics be unhosted after a few months?? maybe im wrong?
Originally Posted by EnervinE
Very nice writeup. This will help me out if I ever decide to add leather seats. Good job!
I noticed you have the same floormats as me. Gotta love Costco. :-)
they deff keep the interior clean as he11 tho
Originally Posted by happy4444
i know i know.. i was gonan do the steering wheel but airbags went off... then i was gonan do the glovebox but it was broken... ill figure something out.
Derrick2k2SE
Nov 19, 2015 10:14 PM
Turbonut
46
Oct 21, 2015 08:28 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
carid
Sep 17, 2015 05:00 AM
sdotcarter
Sep 2, 2015 09:53 PM
anyway, I like the Cefiro door steps.
