broken lug stud repair?
Old Apr 11, 2007 | 06:27 PM
bvtran's Avatar
94c Big Max
how do you guys repair broken lug stud for the front wheel without removing the hub? The back round water shield was in my way so I wasn't able to press it backward. It looks like I have to remove the hub to get to it but doing that might damaging my new wheel bearing which I don't want to go thru it again.
Here is the picture of that round water shield I referred to:
p.s. that's a old picture, please disregard the wheel bearing works.
Old Apr 11, 2007 | 06:30 PM
goon9's Avatar
I replaced my fronts no problem... But I removed the dust shield, donno if that made a difference.
You just need to rotate the hub till you have and opening to put a stud through.
Old Apr 11, 2007 | 10:36 PM
bvtran's Avatar
94c Big Max
how do you remove that round dust shield because that thing was in the way for me to press out the broken stud?
Old Apr 12, 2007 | 12:02 AM
Alex_V
Its tack/spot welded into place. Personally Id leave it so maybe just cut out a section big enough to bash out the stud?
~Alex
Old Apr 12, 2007 | 05:53 AM
goon9's Avatar
I took off my brakes and bashed it till the lip of the dust shield around the hub was exposed. Then I cut the lip and it broke free... I don't remmebr and spot welds, I was sure it was just pressed in place. It's not a big deal the remove, it's real thin metal.
Old Apr 12, 2007 | 06:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
~Alex
it's pressed into place...no welds
Old Apr 12, 2007 | 06:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
drill a hole in the splash shield that lines up to the back of the wheel stud. that should allow the stud to come out.
if not get a dremel and make a notch around the part where the caliper goes.
Old Apr 12, 2007 | 08:57 AM
Mizeree_X's Avatar
Getting back to his roots
See the stud at 1 o'clock? That's where I cut a small piece of the shield away to get the studs out.
Old Apr 12, 2007 | 04:24 PM
bvtran's Avatar
94c Big Max
thanks guy, I'll cut a small portion off that shield so I could stick in a socket to press it out.
therealgoon9,
you said the shield felt off after you cut it off. Does that means after you took it off, then dust shield can not be reused right?
Is it possible I could cut it off enough so I could get a new stud in without discarding the the entire dust shield? I think it's crucial to have it there to limit debris from getting into the wheel bearing area.
Old Apr 12, 2007 | 08:39 PM
DanNY's Avatar
Ad·min·is·tra·tor
therealgoon9,
just cut that small notch out...you should be fine.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
MichMaxFan
Sep 30, 2015 09:18 AM
