Verify my timing...
Verify my timing...
Can you swappers verify that my cam lobes are in the right position? Also when I was adjusting the Intake cams on both banks, on both cylinder 1 and 4 (TDC) I was able to rotate the cam completely, while the exhaust cams spin freely. Is this normal? Cylinder 4 is what concern me the most, I'm uncertain how far down or how close to each other they need to be pointed. Thanks all in advance.
Here are the pics:
Crank:
http://s6.photobucket.com/albums/y24...t=IMGP1193.jpg
Cylinder 1:
http://s6.photobucket.com/albums/y24...t=IMGP1194.jpg
Cylinder 4:
http://s6.photobucket.com/albums/y24...t=IMGP1195.jpg
Here are the pics:
Crank:
Cylinder 1:
Cylinder 4:
Alright, I had a chance to bolt the 3.0 timing on. Like everyone mention before, i was very careful in lining up the links to the various marks on the sprocket. After lining up the chain, I decide to do a test crank to see if the whole unit cranked freely and correctly, well after about 20-30 revolutions, I was able to get the marks on the main chain to line up again. Below were the final placements, however as I look closely on the secondary chain on both banks, I am now 1 link ahead of the mark where I originally lined up (circle mark to the gold link). Is this suppose to happen?
I spoke with Nismology and he assured me if I didn't jump a link (which I'm positive I didn't), it should be okay. He may come on and reconfirm this, but I just wanna get some more opinions since it wouldn't hurt to get more info on this. Everything on the main chain lined up correctly, both banks are 1 link ahead of the marked spot.
Crank Key:
RH Intake sprocket
Crank Key:
RH Intake sprocket
you know what....that does seem a little strange, but as far as i know, if you 100% know that it did not jump a teeth or anything, then you should be fine.
when the colors lined up again, and Cyl#1 is at TDC, then im sure you're good to go.
As long as each secondary sprocket is in the same position relative to the chain (ahead by 1 link) all is well.
Also I'd recommend getting the slack back on the tensioner side before closing it back up.
Edit: Do you have a better picture of the crank sprocket? I can't tell if the colored link is lined up with the notch or not.
I can retake a pic of the crank sprocket again but the crank key is lined with the mark on the oil pump, the sprocket is in between teeth. Also will try to get rid of that slack between the two main sprockets and get it as tight as I can.
Originally Posted by jcy98maxse
As I rotated the assembly, it took a while for the main chain to line up the same way again (shown in pics 1, 2 & 3 above) but as you can see, both gold links was ahead of circle mark of the sec. sproket (Pic 3 & 4). So both banks advanced 1 single link relative to its original position.
I was still uncomfortable about the timing so I redid it one final time. Lined every mark up as it should and left it as is. I made sure there was no slack on the chain; everything is nice and tight, all the marks are inline with the links accordingly.
Here are the final pics:
Crank
RH Bank
LH Bank
Crank
RH Bank
LH Bank
spencerwh1
Jun 30, 2016 05:44 AM
theblue
Oct 3, 2001 09:15 PM
