Foglights but no switch....
Old Apr 15, 2007 | 08:12 PM
Dan_E_Boi84's Avatar
When I bought my 99 Maxima it had fogs but no switch on the multifunction switch. So... I came up with a solution. Not sure if you guys have had this problem so...I thought I'd share. Well... I'm sure you guys know about the independant fog threads. This is the same procedure but instead of cuting the power wire... you've gotta cut the wire going to the ground on the coil side of the relay. Then after you cut it you've gotta ground the wire coming form the relay because the switch works off the ground. When you ground the wire it energizes the relay as long as the headlights are on. This way...everytime the headlights are on the fogs are on also... the only thing is you can't turn them off...but it beats replacing the switch...
Old Apr 15, 2007 | 08:15 PM
maxima_kenny96's Avatar
but switches are so much cooler.
Old Apr 15, 2007 | 08:34 PM
Tatanko's Avatar
Bacon Lover
...and inexpensive, and easy to install.
Old Apr 15, 2007 | 10:34 PM
Fr33way™'s Avatar
Wild for Width
Do they still go out when the brights come on?
Old Apr 15, 2007 | 10:38 PM
ImmaSquashYou's Avatar
ok...so you had fogs..but no switch?? Or just that the switch broke?? I'm not sure if i truly understand why you had to do this. My car has a switch to turn my fogs on/off. But then mine's an i30.
Old Apr 16, 2007 | 04:25 AM
Tatanko's Avatar
Bacon Lover
Originally Posted by Dan_E_Boi84
But aftermarket switches look so nasty... plus I rather have my fogs on when the headlights are on....thats only when I want them on....no reason to turn them off if they provide more light and visibility to oncoming traffic...Plus...thats another thing that can wear out later...
I wasn't referring to aftermarket. Buy a new light stalk.
Old Apr 16, 2007 | 05:42 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
get one off the org....
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
