Repair cracked headlight?
Hey there,
I went out to my Maxima today and noticed a crack in the drivers-side headlight. The crack is about 3/4" long and I know if I don't do something quick water will get into it and fog it up.
I plan on replacing the headlights with some nicer-looking ones in a few months anyways, but for now I wanted to ask...does anybody know of a way of repairing the crack that doesn't look too bad? I could just put some tape or something over it but I don't know how well that'll hold up for a few months and it doesn't exactly look too great...I don't want to one fogged-up headlight and one clear until I have the money for new headlights.
I've heard of that 3M film but have never used it...so that may be a possibility. Any thoughts?
Originally Posted by andrei3333
see through silicone, thats how they repair cracked / stone-chipped windshields
the trick is to buff it somehow after its applied and dried up
I would suggest several different grades of sand paper from very coarse say 1000 to very fine say 300 in 4-5 steps like 1000 .. 800...600...400...300 but i may be wrong, never done this, i think some guys do this to old headlights the get "muddy" from thousands tiny little stone chips, you can look up the stickies or search for headlight renovation
maybe even call up a glass / windshield place and consult with them, just ask what they think and pretend like u want their service, find out what they will do for how much and then to the same thing yourself...
Also these link may be helpful to you as well:
http://forums.maxima.org/showthread.php?t=443410
http://forums.maxima.org/showthread.php?t=493450
Enjoy!
Enjoy!
I believe the 97-99 headlights have plastic lenses so I'm not sure if it's a good idea to try and sand it.
Don't they make some sort of protection film for headlights? That might work.
i thought the 95 - 96 were plastic and 97-99 were glass
i KNOW the headlights are different on those years just dont remember which one is which. the 97-99 are obviously clear and the 95-96 are "muddy"
can anyone confirm / deny this ?
This guy in post # 6 of this very thread , i thought u saw it --->
so plastic ones should not be sanded ? didnt know that , but it is possible then to get the glass ones looking new again ?
and here's a nice write up I stole
Materials you will need:
- 400 Grit Sanpaper
- 800 Grit Sanpaper
- 1000 Grit Sanpaper
- 1500 Grit Sanpaper
- 2000 Grit Sanpaper
- Meguairs Plastx
- Meguairs Fine Cut Cleaner
- Meguairs NXT Wax
- Sanding block
- Bucket of Water
- Microfiber Towels
- Buffer (orbital or highspeed if you have it, if not use microfiber towels)
**Make sure to apply tape around the hood, fender, bumper and etc, whereever its possible to accidently scratch the paint.
When you first start using the 400grit sandpaper, the headlight is going to look like crap, but don't worry...it will clear up as you progress.
- Dip the sandpaper in the bucket of water and start sanding. Make sure the surface is always wet.
-For each grit, sand until the surface is completely smooth and apply even pressure. (ie. sanding block) I took about 7-10mins for each grit, before going to the next grit, I would apply Meguair's Plast-X.
(would really help if you had a high speed polisher but if not it will just take longer by hand.)
- Apply 3 coats of Meguiar's Plast-X with an applicator, wipe off with the microfiber towels
- Now use the Meguiar's Fine Cut Cleaner to remove the fine scratches, use as many coats until you're happy with the results. Wipe off with microfiber towel.
- Apply 2 coats of Meguiar's NXT Wax, to provide the long lasting protection on the headlights. Wipe off with microfiber towel.
**I would recommend applying Meguiar's Plast-X once a month to prevent the headlights from hazing.
Before:
After:
Before:
Left (after) Right (Before)
doctorpullit
Oct 28, 2019 10:58 PM
mkaresh
Mar 12, 2018 06:48 PM
Andy29
Sep 29, 2015 05:32 AM
