2002 Suspension options
Old Apr 19, 2007 | 05:01 AM
silviaguy
Hello Folk, first off I like to state I did a search and unless I didn't use the correct key words (which I might have not of) I was not able to find the answer I was looking for.
I have a '02 Maxima SE and now with over 121,000 miles on the car its time to swap out the Suspension. If I have any complaints of the car the biggest would be the Suspension setup on the car from the factory. I feel it is way to hard (Compared to: My brothers GS400, My Mom's Camry, Friends Q45, and '04 Maxima SE) I am not looking for a extremely soft ride but not as firm as what I have now. I wanted to know if someone has a good suggestion on what setup I should be looking at. Ideally I would like to drive a car with this setup but I know that is going to be a tall order to fill. So I am looking towared you guys heavily to help me out.
Old Apr 19, 2007 | 09:27 AM
jeslopez's Avatar
You may want to find some OEM springs off a GLE model, which are softer than SE springs. When I researched for my setup, I concluded that the softest ride on my GLE would come from stock GLE springs with Tokico struts. The Blues are comparable to stock and the Illumina's are adjustable. Checkout this link for a good write up of different suspension setups: http://maxmods.dyndns.org/index.php?MaximaHandling
Are you sure your poor ride quality isn't due to your struts being worn out? I just installed Tokico Illumina's and H&R sport springs. My ride is definitely stiffer and I feel bumps on the road more, but I prefer the better handling over the softer suspension, which feels a bit too bouncy for me. My struts had 184k miles on them, and with the new setup I have, my car actually rides smoother. I think if you want something softer than the SE suspension, you will need to convert to GLE springs.
Old Apr 19, 2007 | 09:34 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=449807
Old Apr 19, 2007 | 11:12 AM
SoonerFan's Avatar
Cletus
is this the first time suspension for an 02 has even been discussed
if only there was a sticky full of valuable information
Old Apr 19, 2007 | 12:41 PM
jeff5347's Avatar
Originally Posted by Rydicule
I was waiting for this.
hahaha i go to the NYC maxima forum and there is not even a 1/4 of the amount of flames as there si on this forum. I just laugh. Ive been there asking questions only to learn if i did use the search function i answer most of my questions, not all but most. or http://forums.maxima.org/showthread.php?t=368622
Old Apr 24, 2007 | 06:35 AM
Puppetmaster's Avatar
Thread cleaned up, back on topic please.
Old Apr 24, 2007 | 08:54 AM
Teufelhunden's Avatar
get the GLE springs matched with tokico HPs. i believe that will give you a soft but tight ride.
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
09maxshawn11
Sep 30, 2015 10:28 AM
