main seal leak- related to pcv valve?
Could non operation of the pcv valve cause crankcase pressure that would cause a rear main seal leak?- we have a slight leak on a 99 with only 78000 miles on it - or does nissan use bad seals?
Dealer wants $950 to fix it
no a pcv wouldnt cause that. you sure its the rear main and not a oil pan gasket? seems odd that it would go out with so low miles.
also that price is steep to replace a rear main.. r&r (remove and reinstall) of a rear main seal it probably 4 hours using mitchell labor......even at 100 dollars an hour labor (most dealers are 84.99)...it should be more than 400 in labor...id check the estimate to see what you are getting charged for. i work as a ASE tech and my good friend works at nissan, theres no way they should charge that much.
Actually a clogged PCV system could allow excess pressure to build in the crankcase and result in a leak at the rear main seal.
But more likely is that the seal is leaking due to age & wear. Really a common issue on Maximas with miles or age.
rear main is not worth fixing unless you have a major oil leak. they could screw up the trans if its not aligned properly, and it still might leak. i was told that the rms could start leaking again a few months later even with a new seal. bah, mines been leaking and i just added a sealer from mothers that slowed it down to a drip, 6.99 a bottle.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
