Engine cuts out, fuel problem?
Old Apr 24, 2007 | 09:21 PM
ghostmax's Avatar
92VE-5, 165k miles
Car was hesitating on acceleration before. Recently replaced fuel filter, CTS, 2 front coils, plugs, 02 sensor, rear valve cover gasket, fuel pump relay, resistor KS bypass with premium fuel, and cleaned the IAAC/TB/EGR/popcharger filter. Car started to run better for a week or so without hesitation.
Today the car ran fine, parked it for an hour. Then when I started it, it would sputter and die, kinda like it does when the fuel pump fuse is removed (I replaced the fuse with a good one to be sure). Long story short, a mechanic came disconnected the MAFS, fiddled with the TB cable--no improvement. Evenutally he sprayed ether through the air filter, and the car didn't sputter anymore. So I had it towed to the shop (after hours), and he'll look at it tomorrow. Diagnostics is $72! Said he'll check fuel pressure, etc and then quote me for a fix. In the past, I did have to clean the fuel pump harness under the rear seat because it was melting/corroded, but the symptom then was no start at all.
Any ideas? I'm thinking fuel pump, clogged injectors, bad gas... I didn't get the chance to check the ECU for codes before he towed it. Thanks in advance!
Old Apr 24, 2007 | 09:32 PM
x91max
its probably the iac i believe its called. it comes off ur intake manifold.
Old Apr 25, 2007 | 03:34 AM
Greeny's Avatar
¯\(°_o)/¯
If the fuel pump harness is melted,you need to replace it..
Old Apr 25, 2007 | 06:26 AM
internetautomar's Avatar
mod or sell?
check the voltage level at the pump.
Old Apr 25, 2007 | 06:31 AM
mikekantor's Avatar
I think its simpler. Did you tighten the plenum properly when you put it back on?
Last time I replaced a rear injector, I didn’t tighten the plenum hex bolts all the way and it was sputtering just like that because of the vacuum leak.
Old Apr 25, 2007 | 06:51 AM
ghostmax's Avatar
I tightened them up, but they could've loosened up over a week or so when I replaced them.
I'm about to head over to the shop and see what they've found.
Thanks guys.
Old Apr 25, 2007 | 09:11 AM
ghostmax's Avatar
Well I called back, and they said the fuel pump was not working but they are going to keep looking. I told them about the harness being corroded, and I'll guess they'll take a look. I hate having my car at the shop because there's no telling what they're doing. I don't have my FSM with me, what is the resistance at the pump supposed to be?
Old Apr 25, 2007 | 11:29 AM
mod or sell?
ya shoulda asked greeny to stop by, he's in the same state
Old Apr 25, 2007 | 01:15 PM
Greeny's Avatar
¯\(°_o)/¯
It's like a 5 hr drive to memphis from here..
Old Apr 25, 2007 | 01:23 PM
mod or sell?
so that's just a 2.5hr trip in the ve-5
Old Apr 25, 2007 | 01:43 PM
xx-Marshall-xx's Avatar
kthxbye2u
im curious to what plugs your using...
Old Apr 25, 2007 | 01:46 PM
Greeny's Avatar
¯\(°_o)/¯
I'm curious as to why plugs would have anything to do with his car not running?
Unless all six decided to foul out at the same time..
My $ is on the harness plug..
Old Apr 25, 2007 | 04:10 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
3¼ hours in my GXE. Maybe 3 flat once i swap for a 5speed. oh, wait, I'm another 300 miles east of that...
Old Apr 25, 2007 | 05:33 PM
ghostmax's Avatar
Bingo! Turned out to be the melted plug which I should have replaced last time. So he charged me 72 diagnosis + 72 hour labor + 10 supply. I even told him to check the plug.....At least it wasn't worse, but this teaches me to do things the first time.
Thanks guys!
Btw, I run NGK coppers
Old May 1, 2007 | 08:56 PM
ghostmax's Avatar
Thanks guys!
So it's been one week since a section of my fuel pump harness was replaced. I have not had any hesitation on load. I think this is definitely one thing that should be checked if you are experiencing that common symptom.
Old May 4, 2007 | 07:56 PM
5spdMaximaSE's Avatar
I have similar problems, do you mean the harness to the pump under the seat?? and what do I check for? corosion or loose wires..both?
Old May 4, 2007 | 09:08 PM
ghostmax's Avatar
The harness leads to a plug to the fuel pump. The plug was melted on mine.
MAXSE5SPD
Sep 17, 2022 04:00 AM
kjlouis
Nov 24, 2018 06:09 AM
kmitchel
Oct 28, 2015 09:46 AM
Slamrod
Sep 3, 2015 07:38 PM
