What is the proper way to install the valve cover gasket (front) see picture.
Old Apr 25, 2007 | 01:21 PM
Luisjo's Avatar
Hi, i need help this seemed like a "do it yourself" job but when i finished the job it was still leaking (in the lower left corner of the cover) and i thought that "maybe i used too much silicone" and it was not closing properly and there was a gap. the other thing i thought was "wow, maybe i put the gasket maker silicone wrong", then i realized that it was leaking right there to begin with (and other random places in the cover) so maybe i have a bad valve cover? what i really want is a write up or if someone know explain WITH DETAILS... please.
Old Apr 25, 2007 | 02:53 PM
alcatranz518's Avatar
Did you torque it down correctly and in sequence? You should follow FSM instructions for anything like that. I do not know your procedure on the gasket/ sealer, but out of sequence or different torque on the bolts can cause a leak. Also, did you clean the mount surfaces, gasket channels, and corners thoroughly (I use brake cleaner-just be careful to not get that stuff inthe oil in the head)? NO oil should be in those spaces, it will prohibit the sealer from sealing. Mix those two alone and you will have a hefty leak.
Old Apr 25, 2007 | 02:55 PM
Luisjo's Avatar
Originally Posted by alcatranz518
Did you torque it down correctly and in sequence? You should follow FSM instructions for anything like that. I do not know your procedure on the gasket/ sealer, but out of sequence or different torque on the bolts can cause a leak. Also, did you clean the mount surfaces and corners thoroughly? NO oil should be there, it will prohibit the sealer from sealing. Mix those two alone and you will have a hefty leak.
wow.... didn't know there was a sequence, i did cleaned them troguhly, how do i find out the sequence??
Old Apr 25, 2007 | 03:07 PM
General rule of thumb is to start from the middle and work towards the outside (left/ right). Alternating top to bottom as you go bolt to bolt towards the outside.
Tighten them 9-25 ft/lbs then go back through again retorqing at 47-60 ft/lbs. I have the FSM, just I cannot copy/ paste in. If you have it or someone else does that reads this and can do it, its page EM-31 at the bottom of the page.
Old Apr 25, 2007 | 04:26 PM
MaximaSpd85's Avatar
to take it off you didnt pry it up did you? also, there is a sequence like someone stated
Old Apr 25, 2007 | 04:32 PM
Kevlo911's Avatar
Kevlo for President
Download the FSM from www.phatg20.net and follow the procedure.
Old Apr 25, 2007 | 04:41 PM
nlmaxima's Avatar
Do you mean 9-25 inch/lbs and 47-60 inch/lbs. 60 inch/lbs = 5 ft/lbs I have found using a nut driver to be good enough or if you have to use a ratchet hold the head in your palm so you won't over tighten them.
Old Apr 25, 2007 | 06:34 PM
Umm, ya sorry...I meant inch/lbs. I was doing this while studying integrals for a Calculus final. My brain is a little fried. Sorry.
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nintensity
Aug 13, 2015 05:41 PM
Team STILLEN
Aug 10, 2015 04:29 PM
