flapping noise from behind glove box..
Old May 2, 2007 | 07:38 PM
Brooklyn Legend's Avatar
There is an anoying flapping door noise coming from behind the glove box of my cousins 94 maxima SE auto. I have tried to pinpoint were exactly and closest I got after pulling out glove box was it sounds like its coming from the white cylinder that the blower motor goes in. Is there a flap in their that goes bad anyone else had this problem? Is their a fix to this?
Thanks in advance
Old May 2, 2007 | 07:46 PM
JRS89MAX's Avatar
I know theres a flap there that you open and close by the blower motor. my plastic clip broke. I think it controls when you move the ac lever from cold to hot. Or that other button that goes up and down on the ac to let air circulate. one of them two
Old May 2, 2007 | 07:47 PM
92 Max's Avatar
Does it sound like a leaf or something blew into the blower housing? You should be able to remove the blower by removing the three bolts, the electrical connector and the cooling tube. Then look in the housing and see if a bird or something blew in. It could also the a broken cooling tube flapping.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old May 2, 2007 | 07:52 PM
JRS89MAX's Avatar
AHHHHH bird?
Greeny's Avatar
¯\(°_o)/¯
I had a piece of plastic get inside my blower housing....It made a flapping sounds also...
Old May 2, 2007 | 08:01 PM
this is a constant flap noise even when the keys is in Acc(sp?) second click before starting. is its stops for 5 minutes or so and then continues. I did a search and some have said to unplug the harness for the a/c heat controls I dont see how that will stop it. I ahve already tried by unpluging the blower motor and the siver unit that is faciing directly behind the glove and no dice the noise is still there. Any one get any luck by unplugging the harness behind the a/c heat controls?
Old May 2, 2007 | 08:13 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
try pulling the fuse that controls your blower motor and stuff, and seeing fi that helps anything
Old May 2, 2007 | 09:06 PM
ok, so I unpluged a plug that powered the Intake door motor? what is this things function? Is it vital for the A/C heat system to work. It was pleasent not to hear the noise after I unplugged it.
Old May 3, 2007 | 06:50 AM
internetautomar's Avatar
mod or sell?
depends on how much you like controlling where the air goes
Old May 3, 2007 | 08:24 AM
so do you think its the unit the power plug goes into or the lever that is moved by the powering unit? Once in a while I go to a pull parts place, so I want to know what to buy thanks in advance
Old May 3, 2007 | 12:25 PM
mod or sell?
If I knew where my spare control head was I'd be able to tell you for sure
Old May 3, 2007 | 02:19 PM
Hollywood!'s Avatar
OH MY GOD! you hear this sound too!?!?! this tocking (as opposed to ticking) noise has been driving me insane as well. first it was only heard when i had the vents only on "feet" position, now it comes on at random intervals no matter what position (even when off).
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
