Rust help.
so if i get a bernzomatic torch i can just heat up the rust? and it will burn off?
I would rather try this than taking it to a shop, please enlighten me more...
like this: http://www.lowes.com/lowes/lkn?actio...100&lpage=none
thanks,
Alex
thanks,
Alex
You know I've always had good luck with an impact wrench on rusty exhaust components. I was taking the "U" clamp off the exhaust on my MR2 years ago, that was on the car for 100k miles. Normally these just break off when you try to unscrew the rusted on nuts on these. I took my impact wrench and spun these heavily rusted bolts right off with out breaking the 1/2 rusted through "U" clamp. This amazed me and made me realize that rust and the impact wrench work well together.
What I've found it that the Nuts tend to "Rust Weld" themselves to the Bolt and the impacts actually break the weld and spin the nut free.
Of course I agree that any badly rusted or crudded up threads should be cleaned before backing the nut over it and stripping both. I've found a small wire brush the size of a toothbrush works well for this.
thanks,
Alex
thanks,
Alex
thats pb blaster
jesus...
Well i got the torch working and i burned off most of the rust and it seems as if the NY roads this car used to drive on have deteriorated the bolt and stud down... im not sure though...
I think this because the rear bolts are smaller than 14mm (bigger than 12mm and tiny smaller than 13mm) like the front ones and it looks as if the studs have gotten smaller in diameter too...
any thoughts?
jesus...Well i got the torch working and i burned off most of the rust and it seems as if the NY roads this car used to drive on have deteriorated the bolt and stud down... im not sure though...
any thoughts?
thats pb blaster
jesus...
jesus...
any thoughts?
any thoughts?
it wasnt a gas leak, i had the propane torch on too long and it surrounded the igniter.
But as for the rusted fuel neck, i havent had time to fix it because i play baseball everyday so i dont have time to go b!tch at nissan to have them replace it...
anyways... back on topic?
Maybe try a dremel with a metal cutting disc to trim a little around the nut. This will make sparks so wait to you fix your fuel leak.
As a last resort before going to the exhaust shop i would use a breaker bar and hope it doesn't strip. If it strips use a vise grip and try again. If its stripped it don't matter they will melt it off.
I am holding off any work on my car because its leaking fuel too. Not worth blowing up.
you know I also had that problem where they seemed like a small size or where one size was too big and the other was too small, I just put the smaller socket there and hammered it in to place and it worked like a charm.
NOTE If you're gonna try that do it at your own discretion as it might mess you up even more. Worked perfectly for me though and I didnt care cuz I knew I was gonna get my 12 exhaust studs and all 6 ypipe studs changed soon so I did it.
i got the ypipe on but i have some exhaust leaks because i couldnt tighten one of the bolts on the rear headers to the ypipe, and im not sure if i tightened the cat all the way...
But DAYUM!!!!!!!!!!!! me likey teh gains, i needa new clutch to handle the power though
thanks for help and suggestions.
Alex
Alex
RealityCheck
Oct 2, 2015 06:34 PM
