FS: Almost brand new Polk SR series 12" woofer and JBL BP1200.1 amp *PICS*
Ok so up for sale is my almost brand new Polk SR series 12" Dual 4 ohm sub. Looks and plays brand new, only have had it for about a month and its perfect. I still have the owners manual for it also. The sub plays beautifully and has awesome SQ. Polk put alot of R&D into this sub. Here are the specs:
Size 12 -inch
Impedance 4 ohms
Cone Material ABS plastic
Surround Material Butyl rubber
Sealed Box Volume (cubic feet) 0.88
Ported Box Volume (cubic feet) N/A
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil Yes
Sensitivity 85dB
Frequency Response 20 - 0.2k Hz
RMS Power Range (Watts) 100-700
Peak Power Handling (Watts) 1400
Top Mount Depth (inches) 7 13/16
Bottom Mount Depth (inches) 8 3/16
Cutout Diameter or Length (inches) 10 15/16
Vas (liters) 53
Fs (Hz) 30
Qts 0.55
Xmax (millimeters) 16.25
Parts Warranty 3 Years
Labor Warranty 3 Years
I am looking to get 300 shipped for it, which is a steal.
Now for the amp, its a JBL BP1200.1. These amps are under rated and have been benched to put out 1300-1400 watts. The amp has never been blown or repaired and I am the original owner. No issuses at all with it. The only scratches on it are around the screw holes where I had it screwed down and a small rub mark on the top of it which is about 3mm in size. Could be touched up with a marker if you could even notice it. I am looking for 250 shipped for this item. If your looking for the pair I can probably work a deal. If you want pics of the amp let me know.
Size 12 -inch
Impedance 4 ohms
Free-Air No
Dual Voice Coil Yes
Sensitivity 85dB
Vas (liters) 53
Fs (Hz) 30
Qts 0.55
Stagnet04
Oct 11, 2015 08:16 PM
