Swapped Engine, now overheating
Old May 15, 2007 | 03:57 PM
99 Max ES's Avatar
I Swapped a 99 Maxima with a younger 99 Maxima engine from a car with one month different build dates, did not swap ECU's.
Anyways. Now the engine is sometimes overheating when idleing, fans are not being told to turn on when this happens, but the fans do turn on other times. The AC system is open at the moment. dunno if this matters.
the temp gauge sometimes climbs to near the danger zone, then if I turn the car off and right back on the temperature is back to normal healthy range.? this is what seemed most odd to me. Checked all the basics and now im stumped.
Any Ideas, anyone ever see this erradic temp guage condition?
A
Old May 15, 2007 | 06:04 PM
95jr6708's Avatar
what about the thermostat?
Old May 15, 2007 | 06:09 PM
speed racer's Avatar
did you get a warranty on the engine?
Old May 15, 2007 | 06:16 PM
99BlackMaxMS's Avatar
ECTS = Engine Coolant Temperature Sensor
Old May 15, 2007 | 06:19 PM
slinky87's Avatar
are you ssure you plugged your coolant temp sensor connectors on right should be one black one and blue one the black one is usually nasty as hell when you pull the plug so clean it off and double check your connections i had the same thing happen with the fans but no overheating issue after a drive around the block the fans started acting normal again
derekinthez
Nov 13, 2022 04:00 PM
97_GXE
20
Sep 17, 2015 08:12 PM
asianstyle
Sep 10, 2015 11:30 AM
I<3 A32's
Sep 10, 2015 11:07 AM
