RPM Switch "Weatherized" ***Pics***
Old May 16, 2007 | 08:20 AM
Dubbya's Avatar
VK56 Inside
After a recent engine bay wash and hours of trouble shooting to figure out why in the world my Tach wasnt working any more, I found that a fair amount of water had gotten into my Summit RPM Switch. Once I took it apart I quickly realized the weak points of the enclosure design. There is no gasket for the lid and a gapping area where the wires come out. To save myself this problem in the future I decided to make a quick trip to Fry's Electronics and engineer a better enclosure. This is what I came up with.
The supplies...........
Finished...........
Old May 16, 2007 | 08:21 AM
NmexMAX's Avatar
dot dot dot ...
When does your open? IIRC, your last dyno showed no such event.
Old May 16, 2007 | 08:23 AM
Dubbya's Avatar
VK56 Inside
3800 RPM. It does open. Visually verified many times. The switch has been on there since day 1.
Old May 16, 2007 | 08:25 AM
NmexMAX's Avatar
dot dot dot ...
Must be the lack of VTC's for the lack of low-end'ness
Old May 16, 2007 | 08:28 AM
Dubbya's Avatar
VK56 Inside
Lack of EU doesnt help either
Old May 16, 2007 | 08:33 AM
1FSTMAX's Avatar
kinda ot.. but how did you get your rpm switch to open then close again?
Old May 16, 2007 | 08:35 AM
Dubbya's Avatar
VK56 Inside
It only activates at 3800 RPM and above so as soon as RPM's are below the threshold it closes.
If you mean how did I physically open the RPM switch, there are 4 screws.
Old May 16, 2007 | 01:36 PM
NmexMAX's Avatar
dot dot dot ...
IMO, the open/closing of the 2k2 VIAS is negligible. Activating it anywhere from 3600 - 3800 would be fine.
Old May 16, 2007 | 01:47 PM
RA030726's Avatar
I'm nutty for Nissans
why not just install it in under the dash? mine is under the shifter trim.
Old May 16, 2007 | 01:48 PM
NmexMAX's Avatar
dot dot dot ...
Mine is next to my left foot, just above the dead pedal region.
Old May 16, 2007 | 03:49 PM
chopsauce's Avatar
i'm in the process of installing my 00vi,
1) do i need to buy a RPM switch?
2) and if i block off the EGR do i still need an 00 EGR tube guide
3) where would i get block off plates for my swirl valves
4) do i need a new PCV valve
Old May 16, 2007 | 06:16 PM
Tatanko's Avatar
Bacon Lover
Mine is in it's famous location
Old May 16, 2007 | 10:10 PM
killerVQ30DE's Avatar
Only problem with that 'mod' - now the summit rpm switch is even BIGGER - surprised they used such a large enclosure in the first place.
Old May 17, 2007 | 06:42 AM
Dubbya's Avatar
VK56 Inside
Id rather have it bigger than wet again. I didnt install it in the first place, but I guess I could relocate it. I was bored and made a trip to Fry's. My over engineering got the best of me.
Old May 17, 2007 | 05:17 PM
RA030726's Avatar
its better than the guy who used a ziploc/rubber maid container and posted pix here. that was ghetto as hell.
Old May 17, 2007 | 05:51 PM
MDeezy's Avatar
4100 hasnt been bad either... still yet to dyno.
Old May 18, 2007 | 07:13 AM
Dubbya's Avatar
VK56 Inside
I have pictures of a bird's nest in a tupperware box from a Maxus meet.
Old May 18, 2007 | 02:21 PM
aussie983's Avatar
Why not use the rtv to form a gasket on the original lid of the switch? and squirt some where the wires come out too?
Old May 18, 2007 | 03:55 PM
Dubbya's Avatar
VK56 Inside
Because I felt like doing it this way.
Old May 18, 2007 | 04:11 PM
NmexMAX's Avatar
dot dot dot ...
I'm sure lack of CVTC is also a concern. So playing w/ different RPM points on a dyno sounds like a nice idea.
Old May 19, 2007 | 12:35 PM
Zack342's Avatar
nice work but uner the radio/shifter trim makes for easy access
Old May 20, 2007 | 10:24 AM
Flava_24/7's Avatar
Boosted Panda
That would have been my solution. My RPM switch actually has an O ring type of gasket around its lid to seal it, the only area that could allow moisture in is where the wires come out of it. Silicone would solve that easily enough though.
Old May 20, 2007 | 10:26 AM
Flava_24/7's Avatar
Boosted Panda
Under the hood is just as easy. Plus having RCA wires and other wiring for other devices makes it a bit tight there too, at least for me.
In theory you could just mount it any where but for me under the hood was the easiest and fastest solution. No need to run a lot of wire to it.
Old May 21, 2007 | 09:53 AM
Dubbya's Avatar
VK56 Inside
There was no O-Ring on mine. Also this way allows me access with out having to cut through or redo any RTV should I need to open it back up.
gavin68
Sep 18, 2021 12:36 PM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
