a/c clutch bearings
a/c clutch bearings
I m searching on partsamerica.com for a/c clutch bearing and there are a bunch of compressor types:
Comp. Type Dkv14c
Comp. Type Cwv618
Comp. Type Cwv617
Comp. Type Dks16h
Comp. Type Fs10-21
Comp. Type Dkv14d
So which bearing should i get? And if there is any identification on my compressor that will indicate my compressor type???
Any help will be appreciated!
Comp. Type Dkv14c
Comp. Type Cwv618
Comp. Type Cwv617
Comp. Type Dks16h
Comp. Type Fs10-21
Comp. Type Dkv14d
get the manufacturer's part number off the compressor (not the nissan #). part of it will contain one of the #s you listed above.
or, just pull off the pulley, knock out the bearing, and measure it. then go buy a generic ball bearing that matches those specs.
it is not a difficult job, so long as your clutch and pulley don't need to be pulled off with a puller. there's write up in the stickies.
one of these will work....
http://www.houstonbearing.com/Defaul...BEARING*6017@@
litch
123
Jan 4, 2024 07:01 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
