4th gen radiator after VQ35 swap, help please!
My radiator leaks and need to be replaced.
For those who might ask, it's the dual core one, for the automatic transmission.
I noticed that it comes hotter that it used to be with the old VQ30.
I was wondering if the 02 VQ35 powered maxima had a thicker, more efficent radiator than the 4th gen?
If it does, would it fit on to the 4th gen fans shroud?
Also, should I replace the 0.9bar rad. cap by a 1.3bar one?
What would be the advantages of this?
Thanks twice to everyone for any help!
Originally Posted by NmexMAX
How do we know it's running hotter?
Originally Posted by tavarish
have you tried adding coolant?
So if the 4th gen and the 5th gen rad are the same, I will buy a new one, and propely bleed the system. I can buy it on ebay for less than $100.00.
Originally Posted by Kevlo911
4th gens do the same thing.
VQ35's have more cooling passages anyways. Run 65-70% water and the rest coolant.
The 50-50% mix as always been good for our climate conditions.
Originally Posted by nismology
Uh oh. I hope this isn't what I think it is. You're saying excess coolant sprays out of the overflow tank? Does the coolant bubble there on a regular basis?
huhmm.... interesting...
i just noticed a couple of days ago that my radiator (Top 2 corners of each side) is also leaking a bit......
i was actually thinking if its a sealant that seals it up or is it a type of gasket....
because if it is, shoudn't there be a fix for it?
But dont use leak sealant in a bottle, that you put in the coolant.
It's not good for the water pump.
I putted some Automotive GOOP where its leaking and its holding quite good. But I still need to change my radiator.
Maximus and Roadrunner, you guys have a 10yo car, radiator doesnt last forever
. As long as you dont have bubbling in your overflow tank (shrug.... I had it.... HG replacement fixed it :-X) you're good to go
Originally Posted by 97_Roadrunner
Maybe we should start a post for a group buy...
ummmmm.....
http://forums.maxima.org/showthread.php?t=487288
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
