Battery Post Corrosion....Prevention?
I've been having a bit of a problem with battery post corrosion on all my cars. I'll pop the cables and take a wire brush to the terminals but it seems to come back. Is there something I'm not doing? Coating the terminals with ?????? Thanks in advance
Originally Posted by f550maranello2
u need Vaseline....
. If used, would you coat the posts and the cables after attached or coat the posts first then attach the cables? Cheers
I kept getting a greenish corrosion that kept returning no matter what I used. I tried cleaning with baking soda then coating with vaseline, dielectric grease, and regular automotive grease. Nothing would keep it away for any length of time until I bought a can of CRC Terminal Cleaner and a can of CRC Battery Terminal Protector. Not a hint of corrosion for about six months now.
Originally Posted by 99grnmaxgxe
There's also this red grease you can coat it in.
Thanks for info! Cheers
My dad swears to those terminal rings made of felt. He used those and applied generic terminal anti-corrosion gel on the terminals and connectors when he bought his car in 1995. No corrosion whatsoever for 250,000 miles.
I usually clean, apply dielectric grease on the inside of the terminal end and on the terminal, then install, and apply a battery terminal protector. Never had this problem on any of my cars, not a bad idea to reapply the protector/ clean and reapply every oil change.
markevans999
Sep 10, 2015 04:29 PM
