Bangs into gear out of park
Did some searching but nothing really helped as far as my problem went.
When I start my car and I am in park, then I shift to reverse, and sometimes drive, it "Bangs" into gear semi-violently, and the RPM's drop drastically. A few times (like twice) while shifting into Reverse it bangs hard then the whole car dies. It's kind of annoying because the transmission itself shifts fine. I would think the drop resistor would cause hard shifts if it were disconnected/faulty, but this is strictly in Park to other Gears.
Any insight would be appreciated
Originally Posted by ColombianMax
My old Accord used to do that and it was the transmission mounts except the car didnt die...
tranny/engine mounts.
I had the same problem earlier this year. When I looked at the rear transmission mount, it had failed completely.
Pop open your hood.
Start your engine. Stay in your driver's seat. Peek into the engine compartment from the driver's seat as the car is idling. Shift the car to Reverse and Drive with the brake applied. If your mount(s) are bad, your engine will move a lot when you shift into gear.
Pop open your hood.
Originally Posted by 94maxshima
Pffff... my car doesn't go to shops.
Amen to that! unless its like an alignment or possibly for A/C service...or exhaust work anything else I work on figuring it out with you guys and the FSM and the GFs dad
jmlee44
Oct 2, 2022 02:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Bahahaha!
