Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
oil level high
Old Jun 19, 2007 | 06:31 PM
pbn85's Avatar
oil level high
so i took the maxima to Nissan for an oil change and I let the car rest for 6 hours and then checked the oil. Its slightly higher than the H mark. I know overfill is bad but is this really considered dangerous to the engine? Can I continue driving around? I know Nissan always puts the proper amount of oil in cars so Im assuming its ok. But I always thought 4.25 quarts brings level between H and L and the only way to get to H is to add 5 quarts? Correct me if Im wrong
Old Jun 19, 2007 | 06:37 PM
wyche89's Avatar
yeah, the same thing happened with my car when i took it to nissan.. i was worried about it as well, but i dont think its a big deal.. when i change mine, 4.25 quarts always takes it a little above the H mark.. and 5 quarts would take it way above, which i wouldnt even try.. just as long as it doesnt go above that little nub above the full line.. thats what i would consider too much.. thats just my 2 cents, but im not an expert.. if u wanna be absolutely sure, just let some out
Old Jun 20, 2007 | 07:15 AM
Love_00_Max's Avatar
You will be fine as long as you don't put in 5Q you will be fine. 4.25 - 4.5Q is not much off a difference, but 5Q is definetly an overfill..
Old Jun 20, 2007 | 02:52 PM
A33Black's Avatar
I always change the Filter as well and usually 4 quarts even will take it to the Full mark on my VQ30. I also let it drain for 1+ hour until there is no more drip.
Next time, try only 4 quarts then top off from there if necessary.
Old Jun 20, 2007 | 03:52 PM
Bufflomike's Avatar
Sexier Than Simpson
I think they just want to replace another motor for you
Old Jun 20, 2007 | 04:43 PM
pbn85's Avatar
10things
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
foodmanry
Sep 24, 2015 12:02 PM
dcardello
Sep 3, 2015 11:44 PM
