steering wheel shakes on highway...wheel balance or alignment?
I believe I have even tire wear, but whenever I get on the highway the steering wheel starts to shake a little.
Does this mean the wheels need to be balanced or do I need to get an front wheel alignment? And just a toe alignment probably would do right?
Probably balance, alignment doesnt do much for vibration. Alignment helps when you have to steer actively to go straight.
If balance doesnt help then either your rotors are warped, or you have some play in your steering rack and maybe need new tie rods.
Originally Posted by maxima_driver7
it could even be a shifted belt in the tire, in that case get them replaced right away and avoid a big problem
How can you checked if it is a shifted belt? My Maxima started doing this recently.
it could be water in your rims had that happen to me in my bmw, took it to the tire shop and he said that it was water, popped the tore enough and there was about 4-5 ounces of water, with that being said it could be water or unballancing, youll need an alignment when your car starts to steer to the side when you drive hands free (1 second increments only, dont want you to kill anybody
what do u mean my max steers herself isnt she supposed to ? i thought thats what cruise control is made for !!!
and how does water get into tires ? if there was a hole then shouldnt the pressure go down ? maybe condensation ?
On a straight and flat road your car should be able to go straight under steady speed, acceleration, as well as with breaking applied. This should be for far more than one second, and if not then you have brake balance, tire, or alignment issues.
I had this kind of problem when I first got my 97,tried a few things like new tires,balanced and re-balanced....tried new rims tried new rotors,well one was a bit warped anyway but still didnt help. Finally I replaced the LCA's/bushings nad voila,the problem went away. I couldny figure it out cause it was so intermittent,like under 65 I didnt feel it,then at 70 I would but sometimes at 72 it would go away other times it wouldnt.
This is the exact symptoms that I am experiencing. Did you replace the whole LCA or just the bushing?
JoshG
51
Sep 21, 2015 10:41 PM
