Need Help With Clutch
Old Jun 28, 2007 | 09:46 AM
tc97max's Avatar
My clutch squeeks when I push it in. It does this when the car is on or off it does not matter and does it through all gears but does not sqeek when I let the clutch back out only when I push it down. The noise can be heard from inside and out side the car. I dont know if it is some thing as simple as lubing the clutch, I just dont know how to do that so I would like some help here on what you guys might think is making the sound and how to fix it. I appreciate any help.
Old Jun 28, 2007 | 10:15 AM
GStrength's Avatar
Sounds like it's the pedal that needs to be lubricated, the spring on the clutch pedal.
Old Jun 28, 2007 | 10:27 AM
tc97max's Avatar
Thank you but were can I find that spring, is it inside the car or outside underneth the car. What should I lubricate it with?
Old Jun 28, 2007 | 10:49 AM
tc97max's Avatar
anybody else?
Old Jun 28, 2007 | 10:57 AM
KRRZ350's Avatar
My vote is for clutch pedal as well. Inside, under the dash, lay on your back in a really akward position and spray all moving parts with silicone lubricant or ptfe, just don't use wd40.
Old Jun 28, 2007 | 10:59 AM
tc97max's Avatar
Ok man Ill try that thanks and I hope its as simple as that.
Old Jun 28, 2007 | 10:15 PM
tc97max's Avatar
I lubed all moving parts on the inside of the car under the dash and the sound is still coming from the outside. I no longer hear it on the inside but there is still something squeekng on the ouside of the car. This is getting on my nerves and starting to scare me SOME ONE PLEASE HELP ME AND JUST TELL ME WHAT IS WRONG, I see other peoples questions get answered but mine are alway ignored. Please, I am loosing faith in my Maxima because things keep going wrong with it and I cant get any answeres I need to my problems.
Old Jun 29, 2007 | 01:14 AM
PLUMMAXSE's Avatar
Sound to me like your clutch throwout bearing is one squeaking. If so, you have to do as much labor to replace your clutch as to replace the bearing. Most people just live with it. The bearing moves in the housing just a little and after time squeaks or groans. Thats why a bearing, pressure plate and clutch plate come in a clutch kit.
Old Jun 29, 2007 | 04:41 AM
JtzMax's Avatar
Whatchyou say?
lube up the (NOT wit WD40 - stuff is horible!) the fork on the trans too ... I'd lube everything and see if it helps ... I am not really in aggreance with the TOB tho ... ???
Old Jun 29, 2007 | 09:46 AM
tc97max's Avatar
I had the clutch replaced not long ago with the tranny rebuild so I dont know what is wrong. **** this car.
Old Jun 29, 2007 | 10:02 AM
matty's Avatar
There are all moving parts under the dash for the pedal. Get under there with some White Lythium grease and make it speak and see where its coming from.
You hate the car cause of a squeak ??
-matt
Old Jun 29, 2007 | 10:12 AM
tc97max's Avatar
I did spray every moving part under the dash and the sound went away inside the car but I think that is because there was a squeak inside and outside the car. Its the squeak out side the car that I cant figure out. And my car has had lots of problems and you dont want to get me started on that.
Old Jun 29, 2007 | 10:29 AM
matty's Avatar
What are you "spraying" ??
Parts should have lithium grease on them
-matt
Old Jun 29, 2007 | 10:32 AM
tc97max's Avatar
I used what someone here told me to use in this thread, its silicone somthing spray. Got it at autozone. It solved my inside squeak but there is still a sound comming from ouside the car on the driver side.
Old Jun 29, 2007 | 11:51 AM
tc97max's Avatar
........bump
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
