black smoke from exhaust
Running extremely rich(tooo much gas) is the chief cause of black exhaust smoke...
1. stuck open injectors will cause this..
2. Improperly installed o'rings in the injector rail will also cause this issue.
3. possibly a malfunctioning o2 sensor could cause this...(bad wiring also)
4. possibly a bad coolant temp sensor(long shot)(or bad wiring to the sensor)
5.
5.
Originally Posted by mooze
so if its stuck open i must replace?
Yes, a bad injector must be replaced...It may be more than one injector though..
Have you or the previous owner replaced any injectors?
here is link of idle. it just wont correct itself as of now. injectors too?http://s6.photobucket.com/albums/y21...t=SUC50772.flv
not that i know of. even tho they have correct resistance they still mayb bad
Yes it is possible to have an injector ohm out ok,but still malfunction..Not likely,but possible..
And yes,a crappy idle can be caused by bad injectors...
Car work sucks huh?
I dunno dude,it sounds like maybe you have done something wrong during reinstallation of all related parts of the k/s job..
But it may also be just a fluke that an injector or two may have failed at the same you done your work...
? is there anything special in the drivers fender well cause i whipped out the torch to cut my hole for the cia
Well maybe not serious. Just All the wires going to your motor and accessories. I'm a little tempted to quote you in my sig...
You might want to remove the d side plastic fender well and check around in there for burnt wires..
Can you post the ebay link for the injectors(just to make sure you bought the correct injectors)
they're not brand new http://cgi.ebay.com/ebaymotors/ws/eB...4805354&rd=1,1
have the wheel off. will update in a min
adamgalazka
Feb 5, 2023 08:24 AM
ballerchris510
Sep 10, 2015 09:35 PM
