Three easy questions, two for DBM and one for nitrous users.
DBM, which service manual do you suggest, Haynes or Chiltons, or doesn't it make a bit of difference. I'm tired of asking questions like the one I'm about to ask.
How many O2 sensors do our cars have? Do we just have 1 for each cylinder bank, or do we have 1 for each bank and a 3rd farther back to kindof monitor both banks in conjunction.
Now the nitrous question. I asked before about A/F guage vs. EGT guage, and gathered that I should go with the EGT guage instead because A/F guages aren't that great at telling you whether you are running rich or lean. I had an idea however...
Isn't the A/F guage only as accurate as the O2 sensor you have it hooked up to? I may have to replace an 02 sensor as I'm pulling code 0503 (rear bank, cyls 1,3,5.) In that case, wouldn't it be a good idea to run an A/F guage off a brand new sensor, since it will be as accurate as it can ever be? Or do you still suggest getting an EGT guage rather than A/F guage. This leads me to one last question. I asked above how many O2 sensors we have. If the answer to that is 2, then which bank should I run the A/F guage off of ideally, or doesn't it matter? If the answer is three, I assume I should run the A/F guage off of the sensor that monitors the entire exhaust flow, not just one bank, right?
Thanks for putting up with my questions.
I'm not DBM, but I might be able to answer the first two questions:
I've owned both the Haynes and the Chiltons, and I guess I prefer the Haynes a little more (although someone who's done more in depth work to their Max might answer otherwise). Picked up a Haynes for $12.99 at Smack Auto.
The bank for cylinders 1, 3, 5 has an O2 sensor and so does the bank for cylinders 2, 4, 6. And there's an O2 near the cat. Think that's it...
Originally posted by Nealoc187
DBM, which service manual do you suggest, Haynes or Chiltons, or doesn't it make a bit of difference ...
Oxygen sensors
... How many O2 sensors do our cars have? Do we just have 1 for each cylinder bank, or do we have 1 for each bank and a 3rd farther back to kindof monitor both banks in conjunction. ...
Now the A/F is more for show but if can be just as useful as a EGT if you get a seperate O2 sensor for it. You can run the A/F off of any bank you want but remember, 1 bank only tells you teh mixture for 3 cylinders not 6. That is why a seperate should be bought. It will be more accurate and read all 6 cylinders. Right now my A/F is running off the front bank (right in front of valve cover). The EGT will bascially tell you if your running lean or rich as well based on teh temp of your exhaust. It never hurts to have both when playing wiht NOS. Cant cut corners.
James92SE
142
Jan 2, 2024 09:23 AM
Unclejunebug
Apr 2, 2016 05:42 AM
pears
Sep 18, 2015 05:25 AM
