so i used sea foam..
Old Jul 21, 2007 | 02:12 PM
blimblam's Avatar
i poured it into the gas tank cause i needed to clean the injectors and when i turned it on, there was no white smoke or anything coming from the exhaust. or is the white smoke only when poured into the crankcase or intake. did i do something wrong?
Old Jul 21, 2007 | 02:16 PM
Snypa's Avatar
well i can be wrong, but i have never seen it been thrown into the tank,always somewhere in the engine tehn you will see smoke after 5-8 minutes.
LETS WAIT AND SEE.
Old Jul 21, 2007 | 02:18 PM
andrei3333's Avatar
break booster line or something isnt it ?
Old Jul 21, 2007 | 02:21 PM
blimblam's Avatar
i waited around 10-15 minutes before firing it up. i have to go somewhere in a little bit so i'll see what happens then. oh, and you can also use it in the gas tank.
Old Jul 21, 2007 | 02:37 PM
Snypa's Avatar
ok,well have fun........go kill the mosquitos.
Old Jul 21, 2007 | 02:59 PM
aznprid972's Avatar
I don't think you'll get that much smoke, if any, from the gas tank. I noticed a lot of smoke when I seafoam using my brake booster. Smoked for a good 5 minutes or so.
Just let it suck though the brake booster, turn off the engine for 15 minutes or so, then start it back up and you'll see the smoke pour out.
Old Jul 21, 2007 | 04:30 PM
blimblam's Avatar
well i went driving for a bit before i had to go to church. it started stalling so i pulled over into the parking lot started revving it up. went back to creeping, so far so good.
Old Jul 21, 2007 | 08:21 PM
ThurzNite's Avatar
That's fine for cleaning injectors. I think most members use chevron techron fuel system cleaner or BG44k.
The usual use of Seafoam is through the brake booster vacuum line. That's the one that will give u the white smoke.
Jae
Old Jul 21, 2007 | 08:32 PM
blimblam's Avatar
Jae
i may do this sometime during the week since i have about 1/4 or 1/3 of a bottle of sea foam left. i want to see the white smoke lol
Old Jul 21, 2007 | 09:00 PM
the_3d_man's Avatar
you did it wrong. It won't hurt to put it in the tank, but you are supposed to let the engine slowly suck it up through the brake booster line, then turn the car off and let it sit for about 10-15 minutes. then start it up and watch all the smoke pour out. (lots) it only smokes after sitting off 10-15 minutes which basically tells you that it's not just the seafoam burning off. It's the carbon that the seafoam softened up and disolved. (and don't put it in your crankcase. they make other crap for that like AutoRX)
Old Jul 22, 2007 | 05:18 AM
blimblam's Avatar
oh...then i will do that later this week when i have time.
Old Jul 24, 2007 | 10:26 AM
T_Dwyer88's Avatar
seafoam is awesome. just dont do it where cops show up to make sure ur car isnt gonna blow up
Old Jul 24, 2007 | 01:03 PM
pyroz's Avatar
what type of performance difference will it make if i use it in the BB line instead of the gas tank?
Old Jul 24, 2007 | 05:10 PM
the_3d_man's Avatar
It's not made to put in the gas tank. The whole point is to let it get sucked through the intake and past the injectors and through the valves at full concentration, then turn the engine off and let the coated parts sit for a while to help disolve off the carbon. Putting it in the gas tank just dilutes it shoots it slowly into the engine to be burned off.
Old Jul 24, 2007 | 06:23 PM
mofoaka's Avatar
i used it in my gas tank today because i just finished redoing all my valve cover gaskets and knock sensor and ITM gaskets.. i noticed my injectors were causing the car to sputter because they were clogged and i poured full can of seafoam into my tank that was at full. it definitely fixed the problem and my car doesn't sputter anymore.
97_GXE
Sep 15, 2015 06:47 AM
Balkins
Aug 12, 2015 06:39 AM
Proceedbob
May 23, 2002 04:37 PM
SeR
Nov 27, 2000 07:47 AM
Chebosto
Oct 14, 2000 10:48 AM
