remote door locks
I dunno anybody who's done this. When I installed my aftermarket keyless entry, It looked like there were couple parts needed. Maybe the audio/electronics forum can help you. Pearl96max seems to be an expert in this field, find him in the other forum. good luck!
Jae
Jae
Originally Posted by erty67
OK, I'm going to ask the NOOB question. Didn't all 4th gens come with remote entry?
Have you tried programming a key fob?
Jae
Originally Posted by ThurzNite
My car had 2 full function keys and a valet key. There is no keyless entry in my stock gxe base 5sp.
Jae
Jae
I love this place
Originally Posted by dawger
checked the car couldn't ever get the hazard lights to flash guess i am not in luck Thanks for the feedback
car didn't come with remote box in trunk so i put one in from another car and still never could get the hazard lights to flash just wondering what other boxes had to be changed to make it work Thanks
1. unlock and open door with the key
2. lock it with the button, while the door is still opened
3. close the door
4. insert key more than 6 times within 10 seconds.
Could you run an "IVMS communication diagnostic" with and without LCU05 attached to see if there's any differences?
How to activate On-board Diagnosis — Mode I (IVMS communication diagnosis), copy&paste from FSM:
Condition
- Ignition switch: OFF
- Lighting switch: OFF
- Rear window defogger switch: OFF
- Doors: Closed
- Interior lamp: Center “O” position
1. Turn ignition switch “ON”.
2. Return ignition switch to “OFF” and press rear window defogger switch
more than 10 times during 10 seconds.
3. Reaction: Self-diagnostic results indicator lamps should turn on.
4. Rear window defogger switch stays OFF
5. Turn ignition switch “ON” within 5 seconds after the indicator lamps turn on (mine was on anyway, but rest of the procedure worked)
6. Reaction: Indicator lamp turn off
After a second, Mode I is performed
7. Turn ignition switch “OFF” to end Diagnosis
After indicator lamp turns on for 2 seconds then off for 2 seconds, it flashes [cycling ON (0.5 sec.)/OFF (0.5 sec.)] to indicate a malfunction code of the first digit. Then, 1 second after indicator lamp turns off, it again flashes [cycling ON (0.5 sec.)/OFF (0.5 sec.)] to indicate a malfunction code of the second digit. For example, the indicator lamp goes on and off for 0.5 seconds twice and after 1.0 second, it goes on and off for 0.5 seconds four times. This indicates malfunction code “24”.
Code 11 means no errors.
Without LCU05 I get error #55, which means LCU05 -- No response from data line A-1
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
