clicking when i turn
Old Jul 25, 2007 | 12:49 AM
bigdanny's Avatar
i heard a clicking when i turn... i thought it was the outter tie rod end.. but i guess i was wrong. i'm planning to do a steering fluid flush.... what do you think is wrong with my maxi?
Old Jul 25, 2007 | 01:09 AM
mooze's Avatar
cv axle. time 4 new one
Old Jul 25, 2007 | 01:21 AM
SuperJimmy's Avatar
Is it allmost like a machene gun sound? mine are on the fritz at the moment, everytime i turn or acc hard it rattels or *clicks*
Old Jul 25, 2007 | 01:28 AM
mooze's Avatar
yeah and speeds up as the car speeds up
Old Jul 25, 2007 | 06:37 AM
internetautomar's Avatar
mod or sell?
CV axle FTL...
at least they are cheap and easy.
Old Jul 25, 2007 | 07:54 AM
Josh's Avatar
Yeah its a CV just like everyone said, mine just went out yesterday. At least its a easy do-it-yourself job.
Old Jul 25, 2007 | 12:44 PM
DanNY's Avatar
Ad·min·is·tra·tor
don't forget to get some tranny (ATF/MTL) for the job.
Old Jul 25, 2007 | 12:57 PM
rmdl51's Avatar
White_Shadow
Hi, umm do you mean after a CV axles job you need to flush your ATF? I heard also is a good idea to do alingment, is it true?
Old Jul 25, 2007 | 01:01 PM
mod or sell?
when you pull the axle, trans fluid comes out.
you shouldn't need an alignment when you do the axle.
Old Jul 25, 2007 | 01:35 PM
rmdl51's Avatar
White_Shadow
oh! I didn't do the job, mechanic did, I guess he fill it up to the right level because I see no difference on the fluid level stick.
Old Jul 25, 2007 | 02:02 PM
gapboi210's Avatar
Wouldn't u need an alignment since u disconnected the spindle from the strut?
Old Jul 25, 2007 | 04:59 PM
Silverfox's Avatar
it's always good to get an alighnment when you get an oil change. Well, maybe not an alighnment but a check up. I saved on getting new tires after i dropped my 89 cause I keep getting check ups. It's a nice sound (or lack there of) to turn and it be smooth with no clicking. It felt like a new car when it happend to mine. R.I.P. "foxy" 89-06
Old Jul 25, 2007 | 05:23 PM
gapboi210's Avatar
get an alignment when you get an oil change? An alignment won't have anythign to do with the CV axle. When you drop a car you change the geometry of everything and sometimes stress many parts of the suspension.
Are you trying to get to your 15 posts? LOL
Old Jul 25, 2007 | 05:29 PM
mod or sell?
why are you disconnecting the spindle from the strut?
you pop the ball joint out of the knuckle along with the tie rod.
Old Jul 25, 2007 | 07:09 PM
gapboi210's Avatar
will that give you enough play to get the cv axle out? I have never done CV axles on a Max but I have on some other cars where there wasn't enough room to get it out. If you just do it the way you said then yeah I don't see any need for an alignment.
Old Jul 25, 2007 | 07:13 PM
mod or sell?
that's how we do it on most cars.
Old Jul 25, 2007 | 09:28 PM
DanNY's Avatar
Ad·min·is·tra·tor
with the 3rd gen it's even easier...
just unbolt the 3 nuts from the ball joint mount.
pop off the tie rod (if really needed) and it should move enough to get the axle out.
Old Jul 26, 2007 | 07:43 PM
Silverfox's Avatar
No, i was just giving my input. I was told that information when I got my CV's changed. But if that info is wrong, i will bow to the correction. It's been yrs since that was done and I don't drive my 3rd gen anymore. Had to put it down.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
