No gas mileage improvement
Its not technically suppose to improve gas mileage.
It will give you more HP. You should have noticed it at 2 points. 1 Right after you installed the pipe. 2 When you drove about 200-250 miles after resetting your ECU.
I noticed a little increase at 1, and a huge increeease at 2.
Is your check engine light on? You may have a code for a O2 sensor or something
I heard that the ecu will readjust to the new mods without resetting, can anybody else confirm this?
I have to say that I can't recommend the Warpspeed Y-pipe due to the crappy flex section. It sounds like it's common for the flex section to leak, even brand new. When the flex section leaks, this causes a hissing sound under hard acceleration. I'm going to try some exhaust wrap on the flex section to see if that helps. You can read about it here:
http://forums.maxima.org/showthread.php?t=530821
Originally Posted by jobell
To PSCMJ84: I see that you have a Warpspeed y-pipe installed on your Maxima. How do you like it? I saw a bunch of posts bad mouthing Warpspeed. I can't complain. My mechanic didn't mention anything when he installed it. Just that one of the manifold bolts snapped when he tried removing the old y-pipe.
