Have a 95/96 with Keyless Entry? Need a favor...
Hey guys, if you have a 95/96 Maxima with Keyless Entry I could definitely use a favor. I'm looking for a picture of the plug and wires that goes into the Keyless Entry Module.
The module is located on the inside of the passenger rear quarter panel, just a bit towards the front of the car from where the emergency jack is stored. If you pull back the carpeting there you can't miss it. It's a thin metal box with two connectors coming out of it; a gray single wire, and plug with several colored wires. I'm looking for a picture of the larger plug and wires.
Reason I'm looking for this is just to see if the keyless module for '97+ is any different. They have slightly different part numbers, however the only difference I can see is that the mounting points are a bit different. I have a spare '96 module here and was thinking about adding OEM keyless since my '99 only came pre-wired for it.
Thanks guys!
Thanks guys!
ah2002
Mar 9, 2016 01:42 PM
