Search function dead, knock sensor Q
Old Aug 9, 2007 | 09:05 AM
CyMax's Avatar
Alright yes this is most likely a dumb question but the search function is dead and I was wondering if, in order to replace the knock sensor, you have to remove the lower intake manifold?
Old Aug 9, 2007 | 09:32 AM
Greeny's Avatar
¯\(°_o)/¯
Did you find a k/s code?
If so,then yes you need to remove the upper/lower intake manifolds,also the large coolant pipe under the lower intake must be removed.
Old Aug 9, 2007 | 09:46 AM
CyMax's Avatar
Stupid question #2 how do I pull the codes? (insert here)
Old Aug 9, 2007 | 10:24 AM
internetautomar's Avatar
mod or sell?
stickies have more detailed info.
but basically you turn the screw on the ECU and the 2 lights flash out the code.
Old Aug 9, 2007 | 10:49 AM
CyMax's Avatar
Ya, NOW the search wants to work!! Thanks tho!
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
