HELP~DID engine swap~ odo/spedo does not WORK!
Hey I did an engine swap in a 01 max so basically the same as a 4th gen and this forum gets read more and I also have a 4th gen max. But anyway why does my speedometer and odometer not work? what could some reasons be? everything else is fine, no check engine lights, nothing. it worked fine before the swap so i am pretty sure its not the dash itself. please help me out thanks!
Originally Posted by Max Noob
u gotta plug in the cable that the speedo/odo reads off of. it plugs into the top of the tranny case by the firewall. mihgt of came loose during install.??
hate to dig up an old thread - but I had a similar problem with no gauges during my clutch swap this weekend - I had NO gauges or warning lights because my meter fuse kept blowing... I pinched my neutral/reverse switch between the tranny and tranny mount... google brought me to this - but it wasn't much help, had to troubleshoot on my own this time
SOOOOO... if you are looking for why your meter fuse keeps blowing, check your neutral/reverse switch....
Ray229Harris
Sep 16, 2015 08:16 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
[/IMG]
