recommended tire pressure for our cars?
Old Aug 18, 2007 | 06:28 AM
maxima2k2's Avatar
sorry, but what is the recommended tire pressure for our cars, is 32 psi okay on all four? Yeah, its a dumb question
Old Aug 18, 2007 | 07:53 AM
xx-Marshall-xx's Avatar
kthxbye2u
...there should be info on the tires AND in your maxima handbook
Old Aug 18, 2007 | 08:37 AM
nForce's Avatar
The Computer Guy
I have mine at 38 psi I like my tires to last little longer and I dont mind the aggressive ride
Old Aug 18, 2007 | 10:38 AM
prappl's Avatar
I keep mine mid 30's in front mid-high 30's in back.
Old Aug 18, 2007 | 08:11 PM
saxytothemaxima's Avatar
it should say in your armrest. mine says 29. seems low??
I keep mine at 35.
Old Aug 18, 2007 | 08:13 PM
DennisMik's Avatar
Pressure depends on the tires you have, how you drive and what kind of a ride you want.
Most tires are either 36 psi or 44 psi maximum pressure, checked cold. The tire's weight carrying capability is acheived when the tire is inflated to its maximum.
The roughness or smoothness of the ride is controlled a little bit by the tire pressure. The lower the pressure, the softer the ride.
For the best tire wear, the front tires should have more air pressure then the rear tires because a front wheel drive car has more weight on the front tires.
Me personally, I use stock size tires. I run my front tires 6 pounds higher than the rears. My current tires are 44 psi max rated, so I run 38 in the fronts and 32 in the rear. At highter pressure, I don't like the feel when I hit a pot hole or am on rough pavement.
If you have low profile tires and don't have smooth streets, I would suggest running with the pressure on the high side to avoid flat tires from hitting pot holes.
Old Aug 18, 2007 | 08:14 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i like that because your headline thing seems to speak to him. no offense to him.
i keep mine at like 35 or so. one leaks slowly. it has a plug in it. and um... for whatever reason i ended up with front tires who say that the max pressure is 35 so i really can't go higher.
Old Aug 18, 2007 | 08:19 PM
kthxbye2u
oh my gawd!!! i cant stop laughing....
Old Aug 18, 2007 | 09:00 PM
internetautomar's Avatar
mod or sell?
they won't last longer, but you will notice the center wearing out faster due to overinflation.
Old Aug 19, 2007 | 01:25 AM
Greeny's Avatar
¯\(°_o)/¯
ugh.........
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Stagnet04
Aug 16, 2015 11:15 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
