Which alternator do I need 110 or 100 amp
Which alternator do I need 110 or 100 amp...I need a new one and the parts stores have both.
Nissan say "I only have one part number and its the right one so what does it matter?" They are obviously no help and 50% more expensive than a parts store.
the 110 amp model only has 2 wires, the stock alternator has 3.... its not a big issue since the extra wire is just a backup power wire going to a different fuse... make sure when you install it or get it installed that the extra constact from the harness isnt gangling around shorting out somewhere
I've never seen a Max with more than two, are you referring to the small wires in the push connector or something else?
Originally Posted by oldngivout
Just where is the third wire located on this alternator?
Originally Posted by Old Blue 66
So does this mean the stock one is a 100amp?? Id rather go that route..cheaper. I think the 110 amp has an internal regulator. Is that the extra wire??
Originally Posted by MerlotMax
The two alternators are not interchangeable on has the terminals in the plugs are set up like this -- (110amp) or this = (100amp)
Now Im confused!! Which one do I buy??????
I just went to look at the car and it appears there is one plug with two wires plugging into the top of the alternator. There is another thing that appears to be bolted on right next to the wire plug. It has a cover a lot like a spark plug wire.
Anyone have any comments? Thats not the third wire in question is it??
According to the info that I have all 2000 and most 2001 use the 110amp.
